map_suite_gps_tracking_server_supported_devices
Map Suite GPS Tracking Server Supported Devices
We've certified a number of popular GPS tracking devices for use with the Map Suite GPS Tracking Server. Certifying a device means that we have developed and tested a “listener” that enables Map Suite GPS Tracking Server to communicate with the device, and that you'll be able to start using these devices with no further development necessary. Please note that not all of a device's features may be supported, but at a minimum you will be able to see the location of the device on your map.
Certified GPS Tracking Devices
Xexun TK102 and TK102-2
Ultraportable personal tracking device with auto reporting and monitoring via SMS or GPRS.
Manufacturer website
Configuration Guide
Debug Communications Log
Supported Device Messages:
  • LowBattery
  • PanicAlert
  • Move
  • Vibration
Xexun TK103 and TK103-2
Installable device suitable for vehicles or rental devices, featuring quad-band GSM/GPRS and 48-hour battery life.
Configuration Guide
  • LowBattery
  • PanicAlert
  • Move
  • Vibration
Orion OBDtrac
Compact vehicle tracking device that provides easy installation and reporting of OBD information.
Configuration Guide
SANAV CT-24
Ultraportable personal tracking device with panic button, 2 sets of open I/O and real-time tracking capability.
Configuration Guide
  • LowBattery
  • PanicAlert
SANAV CT-58
Vehicle and asset tracker with built-in vibration sensor.
Configuration Guide
  • LowBattery
  • PanicAlert
SANAV GC-101
Ultraportable personal tracking device with panic button. Programmable auto-reporting.
Configuration Guide
  • LowBattery
  • PanicAlert
SANAV GX-101
Designed for permanent installation in vehicles or other high-value assets.
Configuration Guide
  • LowBattery
  • PanicAlert
CalAmp LMU-2000, 3000 and 4000 Series
Installable tri-band device with multiple I/O, vehicle ignition input and peripheral device support.
Listener address: 184.73.199.2<br> Port: UDP 1893<br> Debug Communications Log
  • IgnitionOn
  • IgnitionOff
  • LowBattery
  • AntennaShortage
  • TrailerAttached
  • TrailerDetached
  • SpatialFenceIn
  • SpatialFenceOut
  • SpeedViolation
  • PanicButton
  • GSDMessage
  • FuelGauge
  • EngineTemperature
  • BackupBatteryAlarm
  • AirbagDeployed
  • DoorOpen
  • DoorClose
  • SerialIDPlugged
  • SerialIDUnplugged
  • VehicleAlarm
DCT Antares
Installable quad-band device in a rugged housing, ideal for industrial tracking.
Listener address: 184.73.199.2<br> Port: TCP 1899<br> Debug Communications Log
  • Panic
Enfora MT-GL
Installable device, inexpensive, versatile and features multiple I/O interfaces. Good for vehicles.
Listener address: 184.73.199.2<br> Port: UDP 1890<br> Debug Communications Log
  • Panic
  • TrailerAttached
  • TrailerDetached
Falcom Stepp II
Installable device features a complex scripting system for custom tracking applications.
Listener address: 184.73.199.2<br> Port: TCP 1896<br> Debug Communications Log
  • Panic
Meiligao VT310
AVL GPS tracker for car and fleet management.
Orion EasyTrac
Installable device with multiple I/O ports designed for automotive use (fleet tracking, stolen vehicle recovery, etc.).
Listener address: 184.73.199.2<br> Port: TCP 1865<br> Debug Communications Log
  • IgnitionOn
  • IgnitionOff
  • Panic
  • DeviceLogMainOn
  • DeviceLogMainOff
  • DeviceLogOverMile
  • DeviceLogMove
  • DeviceStartMoving
  • DeviceStopMoving
  • DeviceSpeedAlert
  • DeviceRFIDNumber
  • GeoFenceInGroupNumber
  • MovedDistance
  • GeoFenceOutGroupNumber
Orion SpeedTrac
Installable, waterproof device intended for vehicle, security and recovery tracking.
Port: TCP 1865
  • IgnitionOn
  • IgnitionOff
  • Panic
  • DeviceLogMainOn
  • DeviceLogMainOff
  • DeviceLogOverMile
  • DeviceLogMove
  • DeviceStartMoving
  • DeviceStopMoving
  • DeviceSpeedAlert
  • DeviceRFIDNumber
  • MovedDistance
Writing Your Own Custom Device Support
Don't See Your Device Listed? Adding New Hardware is Easy.
If you have tracking devices that aren't listed here, all is not lost. Map Suite GPS Tracking Server's versatile Device Gateway system and Device Simulator application make it easy for .NET programmers to add support for their own custom or specialty tracking devices in just a few lines of code. (Custom device integration capability on GPS Tracking Server Express Edition is limited; please contact us for details.)
If you aren't development-inclined or don't have the programming resources, ThinkGeo's professional services team can help you integrate your custom hardware into your Map Suite GPS Tracking Server solution. We'll tailor your installation to work with your devices and customize their interaction with the system to meet your specific needs. If you need professional device integration with the GPS Tracking Server, simply let us know.
map_suite_gps_tracking_server_supported_devices.1442456092.txt.gz · Last modified: 2015/09/17 02:14 by admin
