map_suite_geocoder
Map Suite Geocoder
The page was created before Map Suite 10. Map Suite 10.0 organized many classes into new namespaces and assemblies as well as had a few minor breaks in compatibility. The majority of previously built code should work without modification assuming the new namespaces are added. For guidance on upgrading your existing code check out this(http://wiki.thinkgeo.com/wiki/map_suite_10_upgrade_guide).
Map Suite Geocoder is a native geocoding and reverse geocoding component for .NET that lets you convert a street address into a geographic location and vice-versa. It can also deliver additional details like county, FIPS codes, census tract and more. Plus, it ships with an optimized set of United States street data based on the latest TIGER® data from the U.S. Census Bureau.
Product Guides
This guide helps you get you up to speed with integrating the Map Suite Geocoder Edition into your GIS software.
This guide walks you through installing the Geocoder edition on your system and creating a simple GIS application.
This guide walks you through deploying your GIS software using the Geocoder edition into a production environment.
This guide introduces the dependencies Map Suite Geocoder needs with their features, versions and source websites.
API Documentation
  • ThinkGeo.MapSuite.MapSuiteGeocoder
    The MapSuiteGeocoder Edition API documentation covers the ThinkGeo.MapSuite.MapSuiteGeocoder namespace which resides in the MapSuiteGeocoder.dll assembly. It contains all of the MapSuiteGeocoder Edition specific classes such as the map control itself, Overlays, and supported map classes.
Code Samples
All Samples
All samples about Map Suite Services Edition.
Project Templates
These projects show various study cases based on Geocoder Edition
Screenshots
Pinpoint an address on your map almost instantly
Bundled with U.S. street data
Pinpoint an address on your map almost instantly Bundled with U.S. street data
Convert lat/long coordinates to a street address
Get county, elevation & more
Convert lat/long coordinates to a street address Get county, elevation & more
Geocode an entire batch of addresses in one operation
High performance processing
Geocode an entire batch of addresses in one operation High performance processing
Improve geocoding performance by building indexes
1 click gives you greater speed
Improve geocoding performance by building indexes 1 click gives you greater speed
Match input to a specific county, street name, etc.
Customize by writing your own MatchingPlugins
Match input to a specific county, street name, etc. Customize by writing your own MatchingPlugins
Use inexact searches to suggest results
Overcome typos & input errors
Use inexact searches to suggest results Overcome typos & input errors
Includes sample applications with full source code
Copy & paste into your apps
Includes sample applications with full source code Copy & paste into your apps
Change Logs
  • API Change Log
Frequently Asked Questions
  • General Questions
    These frequently asked questions cover GIS and Geocoder edition topics that are not categorized in other areas.
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
map_suite_geocoder.1489549768.txt.gz · Last modified: 2017/03/15 03:49 by tgwikiupdate
