map_suite_geocoder
Map Suite Geocoder
Map Suite Geocoder is a native geocoding and reverse geocoding component for .NET that lets you convert a street address into a geographic location and vice-versa. It can also deliver additional details like county, FIPS codes, census tract and more. Plus, it ships with an optimized set of United States street data based on the latest TIGER® data from the U.S. Census Bureau.
Product Guides
This guide helps you get you up to speed with integrating the Map Suite Geocoder Edition into your GIS software.
This guide explains how to use our custom serialization class to render your Map Suite objects to XML, or other format etc. This allows your GIS application to easily save things such as Layers, Styles, or even whole maps to XML to be recalled at a later time. The guide includes an overview of serialization system, and detailed explanation of the various classes, as well as information on creating your own serializer.
This guide walks you through installing the Geocoder edition on your system and creating a simple GIS application.
This guide walks you through deploying your GIS software using the Geocoder edition into a production environment.
This guide introduces the dependencies Map Suite Geocoder needs with their features, versions and source websites.
API Documentation
  • ThinkGeo.MapSuite.MapSuiteGeocoder
    The MapSuiteGeocoder Edition API documentation covers the ThinkGeo.MapSuite.MapSuiteGeocoder namespace which resides in the MapSuiteGeocoder.dll assembly. It contains all of the MapSuiteGeocoder Edition specific classes such as the map control itself, Overlays, and supported map classes.
Screenshots
Screenshot
Pinpoint an address on your map almost instantly Bundled with U.S. street data
Screenshot
Convert lat/long coordinates to a street address Get county, elevation & more
Screenshot
Geocode an entire batch of addresses in one operation High performance processing
Screenshot
Improve geocoding performance by building indexes 1 click gives you greater speed
Screenshot
Match input to a specific county, street name, etc. Customize by writing your own MatchingPlugins
Screenshot
Use inexact searches to suggest results Overcome typos & input errors
Screenshot
Includes sample applications with full source code Copy & paste into your apps
Code Samples
All Samples
All samples about Map Suite Services Edition.
Project Templates
These projects show various study cases based on Geocoder Edition
Change Logs
  • API Change Log
Frequently Asked Questions
  • General Questions
    These frequently asked questions cover GIS and Geocoder edition topics that are not categorized in other areas.
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
map_suite_geocoder.1441950958.txt.gz · Last modified: 2015/09/11 05:55 by admin
