map_suite_mvc_edition
Map Suite MVC Edition
Map Suite MVC Edition is a class library that allows software developers to easily add interactive maps and professional GIS features to their MVC applications. Packed with the speed and flexibility of MVC, the simple API that makes coding easy, and royalty-free distribution, Map Suite MVC Edition enables you to bring your Internet GIS application to market in record time.
Product Guides
Helps get you up to speed with integrating the Map Suite MVC Edition map control into your GIS software.
Helps get you up to speed with integrating the Map Suite MVC Edition map control with mobile UI into your GIS software.
Introduces the dependencies Map Suite MVC Edition needs as well as their features, versions and source websites.
Walks you through deploying your project using the map control into a windows azure cloud service and register the map control.
API Documentation
  • ThinkGeo.MapSuite.Core
    The Core API documentation covers the ThinkGeo.MapSuite.Core namespace which resides in the MapSuiteCore.dll assembly. It contains all of the core GIS classes that are shared between the different Map Suite edition map controls and servers. It includes such classes as Style, FeatureSource, Layer, Projection etc. This is where the bulk of the classes are for most of the Map Suite products.
  • ThinkGeo.MapSuite.MvcEdition
    The MVC Edition API documentation covers the ThinkGeo.MapSuite.MvcEdition namespace which resides in the MvcEditon.dll assembly. It contains all of the MVC Edition specific classes such as the map control itself, Overlays, and supported map classes.
  • Client JavaScript API Documentation
    This document defines the client JavaScript functions that are applied to the Map's name. In other words, if you add an MVC Edition map control named “Map1” to the view page, then you would call these functions like “Map1.functionName()”.
Code Samples
In addition to the samples below, we have dozens of interactive MVC Edition sample applications available here and MVC Edition mobile sample applications here.
All Samples
All samples about Map Suite MVC Edition.
Project Templates
These projects show various study cases based on Mvc Edition.
Background Maps
InteractiveOverlays
Labeling
Layers & FeatureSources
Miscellaneous
Printing
Projection
Spatial Functions
Styles
Vehicle Tracking
Zooming Panning Moving
Videos
MVC Edition Sample App Walkthrough Video Series
Step through the MVC Edition sample applications and see how they're put together. We'll demonstrate how to use each app, then take you through every part of the source code and show you how it works.
Screenshot
Introduction to the MVC Edition
Screenshot
Map Suite MVC Edition Sample Apps Walkthrough
Creating Custom Styles
Exploring Layers
Exploring Layers
FDO, OGR and GDAL Extension
Printing System Introduction
Tile Cache Generator
Topology Validation
Topology Validation
Screenshots
The MVC Edition screenshots gallery section showcases a wide range of screenshots covering various GIS features of the MVC Edition map control.
No extra coding necessary
Includes panning, zooming, scale bar, mini map & more
No extra coding necessary Includes panning, zooming, scale bar, mini map & more
Track multiple markers
Load meta data from XML
Show details in a popup
Track multiple markers Load meta data from XML Show details in a popup
Automatically track multiple vehicle locations
Track weather features
Automatically track multiple vehicle locations Track weather features
Uses ZedGraph classes
Draw track shapes
Edit and rotate shapes
Save shapes to the servers
Draw track shapes Edit and rotate shapes Save shapes to the servers
Design your own tooltips with custom HTML
Include images
Design your own tooltips with custom HTML Include images
Draw track shapes
Puts you in control
Useful for points & labels
Project your spatial data
Real-time rotation
Connect points using the Great Circle model
Show accurate distances
Connect points using the Great Circle model Show accurate distances
Use an online mapping service for your background
Google, Yahoo, or WMS (third party licensing may apply)
Use an online mapping service for your background Google, Yahoo, or WMS (third party licensing may apply)
Draw an image at a point
Change Logs
  • API Change Log
Frequently Asked Questions
  • All Questions
    All the frequently asked questions about Map Suite MVC Edition.
  • General Questions
  • Background Maps
    These frequently asked questions cover showing how to incorporate 3rd part background map (Google, Bing, etc.) with your application.
  • Labeling
    These frequently asked questions cover various aspects of labeling features.
  • Layers & FeatureSources
    These frequently asked questions cover custom layers and feature sources from which you can get inspired to integrate your own data.
  • Miscellaneous
    These frequently asked questions cover various of other technical features of the products that are not included in other categories.
  • Projection
    These frequently asked questions cover various aspects of projection such as how to re-project your data.
  • Spatial Functions
    These frequently asked questions cover various spatial functions such as union, buffer, merging data etc.
  • Styles
    These frequently asked questions cover displaying your GIS data using various styles. Some examples of styles would include using class breaks, clustering points, heat maps, etc.
  • Vehicle Tracking
    These frequently asked questions cover various features related to vehicle and asset tracking.
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
map_suite_mvc_edition.txt · Last modified: 2017/03/16 09:04 by tgwikiupdate
