map_suite_mvc_edition_interactiveoverlays_samples
Map Suite MVC Edition InteractiveOverlays Samples
Custom Track Line
Custom Track Polygon
Dragged Point Style
Dynamic Info On TrackShapes
EditOverlay Styles
Select with Track Shape
In today’s Desktop project, we combine the skills we learned in the samples “Spatial Query A Feature Layer” and “Track And Edit Shapes”. You can see how we use the event TrackEnded to get the RectangleShape from the tracked shape of TrackOverlay to do the spatial query. In this example, we use a Rectangle but you could also very easily use another shape such as Polygon, Circle, etc. |
Tracked Shapes to WKT
Vertex Tolerance
map_suite_mvc_edition_interactiveoverlays_samples.txt · Last modified: 2015/10/10 07:31 (external edit)
