Note: This page is for ThinkGeo UI WebAPI V12 and above, we highly suggest you to upgrade to this version if you are on an old one. Here is a quick guide how to do it: Updating to ThinkGeo 12. Version 12 supports both .NET Core and .NET Framework, the old versions support .NET Framework only. Here are the wikis for the old version: Version 10 WebAPI and Version 9 WebAPI.
ThinkGeo Web for WebAPI allows you to easily build REST based web services to do the server side rendering, querying and geometric functions in your HTML5/Javascript application utilizing any JavaScript mapping client library (Leaflet, OpenLayers3 & KendoUI).
All the samples are available on NuGet via the link below.
This document covers the ThinkGeo.UI.WebAPI namespace which resides in the ThinkGeo.UI.WebAPI.dll assembly. It includes the map control itself, Overlays, and supported map classes. It also covers all the types in ThinkGeo.Core which is the key dependency of ThinkGeo UI WebAPI.
Details the major changes made in ThinkGeo UI 12 as compared to ThinkGeo UI 10 and earlier.
Yes, absolutely. ThinkGeo UI Web for WebAPI is a user control, so you can easily integrate it into your application just like any other user control from the toolbox. We expose a large amount of APIs that allow you to customize every aspect of the map and the user interface so that they fit in with the look and feel of your application.
You'll need either Microsoft Visual Studio 2019 or Visual Studio Code.
ThinkGeo UI for WebAPI comes with native support for the most popular vector and raster file formats. Check out our Data Formats Guide for details.
ThinkGeo UI controls are designed to be easy to understand and easy to use. While mapping and GIS controls typically have a larger learning curve than other, simpler controls like grids or charts, we feel ThinkGeo has taken the complexity out of mapping and allows you to develop your application in days or weeks instead of months.
The ThinkGeo UI for WebAPI provides specific methods that allow you to create, update and delete map features. Just follow the processes outlined in this diagram.
