thinkgeo_mobile_for_ios
ThinkGeo UI Mobile for iOS
Note: This page is for ThinkGeo UI iOS V12 and above, we highly suggest you to upgrade to this version if you are on an old one. Here is a quick guide how to do it: Updating to ThinkGeo 12. Version 12 supports both .NET Core and .NET Framework, the old versions support .NET Framework only. Here are the wikis for the old version: Version 10 iOS and Version 9 iOS.
ThinkGeo for iOS is a powerful .NET control that lets you add interactive maps and professional-grade GIS to your iPhone® and iPad® apps. Using the power of the Xamarin mobile platform and ThinkGeo's Map Suite together, you can develop native iOS apps using the C# language and .NET libraries you're already familiar with.
Getting Started
Helps you get you up to speed with integrating the ThinkGeo Mobile for iOS map control into your GIS software.
Product Guides
Walks you through installing the ThinkGeo UI control on your system and creating a simple GIS application.
Introduces what licenses are needed and how licensing works for debugging and deploying projects using ThinkGeo UI.
Introduces the dependencies required by ThinkGeo Mobile for iOS, along with their features, versions and source websites.
Lists the various GIS data formats that are supported by the ThinkGeo UI map control, as well as any caveats to be aware of with certain formats.
Describes how to upgrade to ThinkGeo UI 12 from previous versions of ThinkGeo UI or ThinkGeo Map Suite.
Explains how to use ThinkGeo UI's style system to beautifully represent your GIS mapping data. The guide includes an overview of styles, a detailed explanation of the various styles that ship with ThinkGeo, as well as a step-by-step guide to creating your own custom styles.
Explains how to use our custom serialization class to render your ThinkGeo objects to XML, or other format etc. This allows your GIS application to easily save things such as Layers, Styles, or even whole maps to XML to be recalled at a later time.
Walks you through various ways you can increase performance in your .NET mapping application.
Code Samples
All the samples are available on NuGet via the link below.
Package
API Documentation
  • ThinkGeo.UI.iOS
    This document covers the ThinkGeo.UI.iOS namespace which resides in the ThinkGeo.UI.iOS.dll assembly. It includes the map control itself, Overlays, and supported map classes. It also covers all the types in ThinkGeo.Core which is the key dependency of ThinkGeo UI iOS.
Change Logs
Frequently Asked Questions
  • Do I have control over how the map looks and fits into my application?
    Yes, absolutely. ThinkGeo UI Mobile for iOS is a user control, so you can easily integrate it into your application just like any other user control from the toolbox. We expose a large amount of APIs that allow you to customize every aspect of the map and the user interface so that they fit in with the look and feel of your application.
  • What other software is required to work with ThinkGeo UI for iOS?
    You'll need either Microsoft Visual Studio 2019 or Visual Studio Code.
  • What type of map data does ThinkGeo UI for iOS Support?
    ThinkGeo UI for iOS comes with native support for the most popular vector and raster file formats. Check out our Data Formats Guide for details.
  • How big of a learning curve is there to using ThinkGeo UI for iOS?
    ThinkGeo UI controls are designed to be easy to understand and easy to use. While mapping and GIS controls typically have a larger learning curve than other, simpler controls like grids or charts, we feel ThinkGeo has taken the complexity out of mapping and allows you to develop your application in days or weeks instead of months.
  • Where do I go if I need help with ThinkGeo UI for iOS?
  • How do I create/update/delete features on the map?
    The ThinkGeo UI for iOS provides specific methods that allow you to create, update and delete map features. Just follow the processes outlined in this diagram.
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
thinkgeo_mobile_for_ios.1589920218.txt.gz · Last modified: 2020/05/19 20:30 by benbai
