ThinkGeo Cloud ReverseGeocoding provides RESTful APIs to find an address from a location. Check out the online sample for a quick look.
ThinkGeo Cloud ReverseGeocoding provides the following Restful APIs.
<!-- Get reverse geocoding for point -->
HTTP GET
https://cloud.thinkgeo.com/api/v1/location/reverse-geocode/{pointY},{pointX}
<!-- Get reverse geocoding for points -->
HTTP POST
https://cloud.thinkgeo.com/api/v1/location/reverse-geocode/multi
[ { "coord": "string", // The coordinates of the point. The format is: y,x. "srid": int, // The SRID (coordinate system) in which to express the result. Defaults to 4326. "proj4String": "string", // The Proj4String (coordinate system) in which to express the result. "lang": "string", // The language in which to express the result. "searchRadius": int, // The maximun radius around the input point to search for places. Defaults to 200. "searchRadiusUnit": "Meter", // The unit of measure in which the SearchRadius is expressed. Defaults to "Meter". "maxResults": int, // The maximum number of results to return. Defaults to 20. "locationCategories": "string", // The categories of locations to include in the result set. The default value is "Common". "locationTypes": "string", // Filters the resulting locations by type. Multiple types should be separated by a comma. Defaults to no filter. "verboseResults": bool, // Indicates whether the results should be verbose or not. When false, the results will have fewer properties. Defaults to false. "distanceFromQueryFeatureUnit": "Meter" // The unit of measure in which the distance is expressed. Defaults to "Meter". } ]
<!-- Get reverse geocoding for area -->
HTTP GET
https://cloud.thinkgeo.com/api/v1/location/reverse-geocode/area?wkt={polygon}
<!-- Get reverse geocoding for line -->
HTTP GET
https://cloud.thinkgeo.com/api/v1/location/reverse-geocode/line?wkt={line}
<!-- Get place by Id -->
HTTP GET
https://cloud.thinkgeo.com/api/v1/location/place/{placeId}
<!-- Get location cateogires -->
HTTP GET
https://cloud.thinkgeo.com/api/v1/location/reverse-geocode/location-categories
No parameters.
<!-- Get common location cateogires -->
HTTP GET
https://cloud.thinkgeo.com/api/v1/location/reverse-geocode/location-categories/common
No parameters
ThinkGeo Cloud ReverseGeocoding does not allow anonymous users to access. Before working with these APIs, you need to get your own clients. A new account come with two clients: NativeConfidential and JavaScript. See more details at here.
The SDK for .NET enables developers to build .NET application that uses the ThinkGeo Cloud services. The NuGet package can be found at ThinkGeo.Cloud.Client or you can install this package with PM by running the command: Install-Package ThinkGeo.Cloud.Client -Version VERSION_TO_BE_INSTALLED, also you can check out the ThinkGeoCloudReverseGeocodingSample-ForWpf for the start.
This documentation convers the ThinkGeo.Cloud.ReverseGeocodingClient class. It contains all of the members such as Constructors, Methods, Properties and Events.
The SDK for JavaScript enables developers to directly access ThinkGeo Cloud services from JavaScript code running in brower. This SDK can be found at thinkgeocloudclient-js. The ReverseGeocoding sample shows how to work with this SDK.
