thinkgeo_cloud_projection
ThinkGeo Cloud Projection
ThinkGeo Cloud Projection provides RESTful APIs to re-project a point, line, or polygon shape between two coordinate systems. Check out the online sample for a quick look.
RESTful APIs
* Try it Online: All the ThinkGeo Projection RESTful APIs can be tested online following the instructions below:
ThinkGeo Cloud Geocoding provides the following Restful APIs:
Project Point
Converts a point from one spatial reference system to another.
HTTP GET
https://cloud.thinkgeo.com/api/v1/projection/{pointY},{pointX}
URL Parameters - All parameters for this API are required and must be specified on each request.
  • pointY: The Y coordinate of the point.
  • pointX: The X coordinate of the point.
  • fromProj: The EPSG/ESRI ID or Proj4 projection string describing the original spatial reference system in which the geometry is expressed. If using a Proj4 string, the value should be URL-encoded.
  • toProj: The EPSG/ESRI ID or Proj4 projection string describing the target spatial reference system that you want the geometry reprojected to. If using a Proj4 string, the value should be URL-encoded.
Visit ProjectPoint and click “Try It Out” to explore this API online.
Project Geometry
Converts geometry in Well Known Text format from one spatial reference system to another.
HTTP GET
  • wkt: The geometry that you want to reproject.
Visit ProjectGeometry and click “Try It Out” to explore this API online.
Consume from Client Side
ThinkGeo Cloud Projection does not allow anonymous users to access the API. Before working with these APIs, you will need to register with ThinkGeo Cloud and create your own clients. A new account come with two clients: NativeConfidential and JavaScript. See more details at here.
SDK for .NET
API Documentation
  • ThinkGeo.Cloud.Projectionclient
    This documentation convers the ThinkGeo.Cloud.Projectionclient class. It contains all of the members such as Constructors, Methods, Properties and Events.
SDK for JavaScript
Samples
Online Sample:
Coming soon
Desktop Sample:
Coming soon
Web Sample:
Coming soon
Mobile Sample:
Coming soon
thinkgeo_cloud_projection.1552338094.txt.gz · Last modified: 2019/03/11 21:01 by brianr
