ThinkGeo Cloud Projection provides RESTful APIs to re-project the shape between two projections. Check out the online sample for a quick look.
* Try it Online: All the ThinkGeo Projection RESTful APIs can be tested online following the instructions below:
ThinkGeo Cloud Geocoding provides the following Restful APIs:
Converts a point from one spatial reference system to another.
HTTP GET
https://cloud.thinkgeo.com/api/v1/projection/{pointY},{pointX}
URL Parameters
system in which the geometry is expressed. If using a Proj4 string, the value should be URL-encoded.
system that you want the geometry reprojected to. If using a Proj4 string, the value should be URL-encoded.
Converts geometry in Well Known Text format from one spatial reference system to another.
HTTP GET https://cloud.thinkgeo.com/api/v1/projection
URL Parameters
ThinkGeo Cloud Projection does not allow anonymous users to access the API. Before working with these APIs, you will need to register with ThinkGeo Cloud and create your own clients. A new account come with two clients: NativeConfidential and JavaScript. See more details at here.
This documentation convers the ThinkGeo.Cloud.Projectionclient class. It contains all of the members such as Constructors, Methods, Properties and Events.
