ThinkGeo Cloud Projection provides RESTful APIs to re-project the shape between two projections. Check out the online sample for a quick look.
* Try it Online: All the ThinkGeo Projection RESTful APIs can be tested online following the instructions below:
ThinkGeo Cloud Geocoding provides the following Restful APIs:
<!-- Converts a point from one spatial reference system to another -->
HTTP GET
https://cloud.thinkgeo.com/api/v1/projection/{pointY},{pointX}
system in which the geometry is expressed. If using a Proj4 string, the value should be URL-encoded.
system that you want the geometry reprojected to. If using a Proj4 string, the value should be URL-encoded.
<!-- Converts geometry in Well Known Text format from one spatial reference system to another -->
HTTP GET
ThinkGeo Cloud Projection does not allow anonymous users to access. Before working with these APIs, you need to get your own clients. A new account come with two clients: NativeConfidential and JavaScript. See more details at here.
The SDK for .NET enables developers to build .NET application that uses the ThinkGeo Cloud services. The NuGet package can be found at ThinkGeo.Cloud.Client or you can install this package with PM by running the command: Install-Package ThinkGeo.Cloud.Client -Version VERSION_TO_BE_INSTALLED
, here is the complete API List. Also you can check out the ThinkGeoCloudSample for a start.
This documentation convers the ThinkGeo.Cloud.Projectionclient class. It contains all of the members such as Constructors, Methods, Properties and Events.
