ThinkGeo Cloud Maps WMS provides an API with which you can retrieve map images through a standards-compliant WMS (Web Map Service). This can be either a single image of a complete map, or one tile from a multi-tile map.
ThinkGeo Cloud Maps WMS provides the following RESTful API:
Retrieve a map image via WMS.
HTTP GET https://cloud.thinkgeo.com/api/v1/maps/wms
URL Parameters
Visit GetWmsMap and click “Try It Out” to explore this API online.
At the NuGet Package Manager terminal, you can install this package by running the command: Install-Package ThinkGeo.Cloud.Client -Version VERSION_TO_BE_INSTALLED
. You can also check out ThinkGeo on GitHub for samples utilizing the ThinkGeo Cloud Client.
Online Sample:
Coming soon
Web Sample:
Coming soon
Desktop Sample:
Coming soon
Mobile Sample:
Coming soon
