ThinkGeo Cloud Maps WMS provides a RESTful API to get map images through WMS (Web Map Service).
ThinkGeo Cloud Geocoding provides the following RESTful API:
Consume the map tiles via Wms.
HTTP GET https://cloud.thinkgeo.com/api/v1/maps/wms
URL Parameters
ThinkGeo Cloud Projection does not allow anonymous users to access the API. Before working with these APIs, you will need to register with ThinkGeo Cloud and create your own clients. A new account comes with two clients: NativeConfidential and JavaScript. See more details at here.
The SDK for .NET enables developers to build .NET applications that use the ThinkGeo Cloud services. The NuGet package can be found at ThinkGeo.Cloud.Client or you can install this package with PM by running the command: Install-Package ThinkGeo.Cloud.Client -Version VERSION_TO_BE_INSTALLED, also you can check out the ThinkGeoCloudSample for the start.
