thinkgeo_cloud_maps_wms
ThinkGeo Cloud Maps WMS
ThinkGeo Cloud Maps WMS provides a RESTful API to get map images through WMS (Web Map Service).
RESTful APIs
ThinkGeo Cloud Geocoding provides the following RESTful API:
<!-- Consume the map tiles via Wms -->
HTTP GET
https://cloud.thinkgeo.com/api/v1/maps/wms
  • Request: Requried. The type of the request. Acceptable values are “GetMap”, “GetCapabilities”.
  • Service: Requried. The service name. Must be “WMS”. Default value: WMS
  • Version: Requried. The version of the WMS. Now, it supports “1.1.1” and “1.3.0”. Default value: 1.1.1
  • Layers: Required for “GetMap”. The layers of the requested image. Use “,” as the separator for the multiply layers.
  • Styles: Required for “GetMap”. The styles of the requested image. Use “,” as the separator for the multiply styles.
  • Format: Required for “GetMap”. The format of the requested image.
  • Width: Required for “GetMap”. The width of reqeusted image in pixels. Default value: 512
  • Height: Required for “GetMap”. The height of the requested image in pixels. Default value: 512
  • Srs: Required for “GetMap”. The coordinate refrenence system in which the BBox is specified. It is used in version “1.1.1”. Default value: EPSG:3857
  • Crs: Required for “GetMap”. The coordinate refrenence system in which the BBox is specified. It is used in version “1.3.0”.
  • BBox: Required for “GetMap”. The bounding box of the requested image. The valid format is “minX,minY,maxX,maxY”.
  • Exceptions: The output format of the exception.
  • Transparent: Indicates whether the requested image should have an alpha channel.
  • Hit Try it Out button below GetWmsMap to test it online.
Consume from Client Side
ThinkGeo Cloud Projection does not allow anonymous users to access the API. Before working with these APIs, you will need to register with THinkGeo Cloud and create your own clients. A new account comes with two clients: NativeConfidential and JavaScript. See more details at here.
SDK for .NET
The SDK for .NET enables developers to build .NET application that uses the ThinkGeo Cloud services. The NuGet package can be found at ThinkGeo.Cloud.Client or you can install this package with PM by running the command: Install-Package ThinkGeo.Cloud.Client -Version VERSION_TO_BE_INSTALLED, also you can check out the ThinkGeoCloudSample for the start.
SDK for JavaScript
thinkgeo_cloud_maps_wms.1551720845.txt.gz · Last modified: 2019/03/04 17:34 by sacha
