thinkgeo_cloud_elevation
ThinkGeo Cloud Elevation
ThinkGeo Cloud Elevation provides a way to get elevation data from the ThinkGeo Cloud service. Check out Get Elevation Along Path for a quick look.
The Elevation service supports querying of elevation data by points, lines and polygons and uses SRTM and NED13 as its underlying elevation source data. It accepts three basic types of input:
  • Points - Returns the elevation at the specific coordinate requested, interpolated if necessary between the nearest values in the source data.
  • Lines - Returns the result of dividing the line into segments and getting the elevation of each division point. Can also return the slope grade in degrees of each segment. To fine-tune, you can specify either how many segments to divide the line into, or how long you want each segment to be.
  • Polygons - Returns the result of dividing the polygon into a grid and getting the elevation of the center point of each grid cell. You can specify an interval distance to control how far apart each point will be from the others.
RESTful APIs
* Try it Online: All of the ThinkGeo Cloud RESTful APIs can be tested online by following the instructions below:
  • Get a ThinkGeo Cloud Client Key. Check out ThinkGeo Cloud Client Keys Guideline to see how to acquire and apply one. All ThinkGeo Cloud evaluations are FREE for 60 days.
  • Visit our ThinkGeo Cloud API Explorer, click the “Authorize” button at the top and enter your client credentials. You are then free to play with all the APIs online.
ThinkGeo Cloud Elevation provides the following RESTful APIs:
Get Elevation of Point
Get the elevation at a single coordinate.
HTTP GET
https://cloud.thinkgeo.com/api/v1/elevation/{pointY},{pointX}
URL Parameters
  • pointY: The Y coordinate of the point.
  • pointX: The X coordinate of the point.
Visit GetElevationOfPoint and click “Try It Out” to test this API online.
Get Elevation of Points (Batch Request)
Get the elevation for each point in a batch of points (up to 1,000 points maximum per batch).
HTTP POST
https://cloud.thinkgeo.com/api/v1/elevation/point/multi
POST Body (Content-Type: application/json)
    "coord": "string", // The coordinates of the point. The format is: y,x.
    "elevationUnit": "string" // Optional. The measurement unit in which the elevation result is expressed. Defaults to "Feet".
    "srid": int, // Optional. The SRID of the input feature's coordinate system. Defaults to 4326.
    "proj4String": "string", // Optional. The Proj4 string of the input feature's coordinate system.
Each item in the batch can locally override a parameter specified on the request URL (for instance, if you have a batch of points that use multiple coordinate systems).
URL Parameters
  • srid: Optional. The SRID of the input feature's coordinate system. Defaults to 4326.
  • proj4String: Optional. The Proj4 string of the input feature's coordinate system.
  • ElevationUnit: Optional. The measurement unit in which the elevation result is expressed. Defaults to "Feet".
Visit GetElevationsOfPointsBatch and click “Try It Out” to explore this API online.
Get Elevation of Line
Get the elevation of each sample point along a line.
HTTP GET
https://cloud.thinkgeo.com/api/v1/elevation/line
URL Parameters
  • wkt: The Well Known Text (WKT) of a line feature to get the elevation.
  • NumberOfSegments: Optional. Splits the requested line into this many segments, then calculates elevation of each point joining the segments.
  • ElevationUnit: Optional. The unit of measure in which the elevation result is expressed. Defaults to "Feet".
  • IntervalDistance: Optional. Splits the requested line into intervals of this length. The unit of measure for this distance is specified by the IntervalDistanceUnit parameter.
  • IntervalDistanceUnit: Optional. The unit of measure in which the IntervalDistance is expressed. Defaults to "Feet".
Visit GetElevationOfLine and click “Try It Out” to explore this API online.
Get Elevation of Area
Get the elevation of a matrix of points within an area.
HTTP GET
https://cloud.thinkgeo.com/api/v1/elevation/area
URL Parameters
  • wkt: The Well Known Text (WKT) of a polygon feature to get the elevation.
  • IntervalDistance: Optional. The distance between every two points in the area matrix. Elevation of each point will be calculated and returned. Defaults to 1000.0. The unit of measure for this distance is specified by the IntervalDistanceUnit parameter.
Visit GetElevationOfArea and click “Try It Out” to explore this API online.
Get Grade of Line
Get the grade (slope) in degrees of a line, optionally split into segments.
HTTP GET
https://cloud.thinkgeo.com/api/v1/elevation/grade/line
URL Parameters
  • wkt: The Well Known Text(WKT) of the line feature to get the grade.
Visit GetGradeOfLine and click “Try It Out” to explore this API online.
Consume From Client Side SDKs
Sample Code
This snippet uses the .NET ThinkGeo Cloud Client SDK to get the elevation of a line by dividing it into 15 segments and taking samples at each segment point. The response is expressed in meters.
using ThinkGeo.Cloud;
LineShape line = new LineShape("LINESTRING(-12359831.643855993 4167388.583607652,-12358190.636404995 4167794.6553204176)");
ElevationClient elevationClient = new ElevationClient("Your Client ID", "Your Client Secret");
elevationClient.BaseUris.Add(new Uri("https://cloud.thinkgeo.com"));
var response = elevationClient.GetElevationOfLine(line, 3857, numberOfSegments: 15, elevationUnit: DistanceUnit.Meter);
Samples
Online Sample:
Desktop Sample:
Web Sample:
Coming soon
Mobile Sample:
Coming soon
thinkgeo_cloud_elevation.1552337194.txt.gz · Last modified: 2019/03/11 20:46 by brianr
