ThinkGeo Cloud Elevation provides a way to get elevation data from the ThinkGeo Cloud service. Check out Get Elevation Along Path for a quick look.
The Elevation service supports querying of elevation data by points, lines and polygons and uses SRTM and NED13 as its underlying elevation source data. It accepts three basic types of input:
* Try it Online: All of the ThinkGeo Cloud RESTful APIs can be tested online by following the instructions below:
ThinkGeo Cloud Elevation provides the following RESTful APIs:
Get the elevation at a single coordinate.
HTTP GET
https://cloud.thinkgeo.com/api/v1/elevation/{pointY},{pointX}
URL Parameters
Visit GetElevationOfPoint and click “Try It Out” to test this API online.
Get the elevation for each point in a batch of points (up to 1,000 points maximum per batch).
HTTP POST https://cloud.thinkgeo.com/api/v1/elevation/point/multi
POST Body (Content-Type: application/json)
[ { "coord": "string", // The coordinates of the point. The format is: y,x. "elevationUnit": "string" // The measurement unit in which the elevation result is expressed. Defaults to "Feet". "srid": int, // The SRID of the input feature's coordinate system. Defaults to 4326. "proj4String": "string", // The Proj4 string of the input feature's coordinate system. } ]
Each item in the batch can locally override a parameter specified on the request URL (for instance, if you have a batch of points that use multiple coordinate systems).
URL Parameters
Visit GetElevationsOfPointsBatch and click “Try It Out” to explore this API online.
Get the elevation of each sample point along a line.
HTTP GET https://cloud.thinkgeo.com/api/v1/elevation/line
URL Parameters
Visit GetElevationOfLine and click “Try It Out” to explore this API online.
Get the elevation of a matrix of points within an area.
HTTP GET https://cloud.thinkgeo.com/api/v1/elevation/area
URL Parameters
Visit GetElevationOfArea and click “Try It Out” to explore this API online.
Get the grade (slope) in degrees of a line, optionally split into segments.
HTTP GET https://cloud.thinkgeo.com/api/v1/elevation/grade/line
URL Parameters
Visit GetGradeOfLine and click “Try It Out” to explore this API online.
Sample Code
This snippet uses the .NET ThinkGeo Cloud Client SDK to get the elevation of a line by dividing it into 15 segments and taking samples at each segment point. The response is expressed in meters.
using ThinkGeo.Cloud; using ThinkGeo.MapSuite.Shapes; LineShape line = new LineShape("LINESTRING(-12359831.643855993 4167388.583607652,-12358190.636404995 4167794.6553204176)"); ElevationClient elevationClient = new ElevationClient("Your Client ID", "Your Client Secret"); elevationClient.BaseUris.Add(new Uri("https://cloud.thinkgeo.com")); var response = elevationClient.GetElevationOfLine(line, 3857, numberOfSegments: 15, elevationUnit: DistanceUnit.Meter);
Online Sample:
Desktop Sample:
