thinkgeo.mapsuite.wpfdesktopedition.vertexremovededitinteractiveoverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs
Provides data for the VertexRemoved. event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs
VertexRemovedEditInteractiveOverlayEventArgs()
  • Constructor of VertexRemovedEditInteractiveOverlayEventArgs class.
VertexRemovedEditInteractiveOverlayEventArgs(Feature,Vertex)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#VertexRemovedEditInteractiveOverlayEventArgs.28Feature.2C_Vertex.29
  • affectedVertexFeature
    • Type:Feature
    • Description:This parameter specified the affectedVertex feature property.
  • removedVertex
    • Type:Vertex
    • Description:This parameter specified the target vertex removed.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#MemberwiseClone.28.29
AffectedVertexFeature
Gets or sets the Feature to be used to remove vertex.
RemovedVertex
Gets or sets the vertex removed.
thinkgeo.mapsuite.wpfdesktopedition.vertexremovededitinteractiveoverlayeventargs.1442912258.txt.gz · Last modified: 2015/09/22 08:57 by admin
