thinkgeo.mapsuite.wpfdesktopedition.vertexremovededitinteractiveoverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs
Provides data for the VertexRemoved. event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs
VertexRemovedEditInteractiveOverlayEventArgs()
Constructor of VertexRemovedEditInteractiveOverlayEventArgs class.
VertexRemovedEditInteractiveOverlayEventArgs(Feature,Vertex)
  • affectedVertexFeature
    • Type:Feature
    • Description:This parameter specified the affectedVertex feature property.
  • removedVertex
    • Type:Vertex
    • Description:This parameter specified the target vertex removed.
AffectedVertexFeature
Gets or sets the Feature to be used to remove vertex.
RemovedVertex
Gets or sets the vertex removed.
thinkgeo.mapsuite.wpfdesktopedition.vertexremovededitinteractiveoverlayeventargs.1442546237.txt.gz · Last modified: 2015/09/18 03:17 by admin
