<!– Class –> Provides data for the VertexRemoved. event.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs</a>
*System.Object System.EventArgs *ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs
![]() | Constructor of VertexRemovedEditInteractiveOverlayEventArgs class. | ||
![]() | Feature, Vertex | Constructor of VertexRemovedEditInteractiveOverlayEventArgs class. |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Object | ||
![]() | Object |
![]() | Feature | Gets or sets the Feature to be used to remove vertex. | |
![]() | Vertex | Gets or sets the vertex removed. |
Name | Type | Description |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#VertexRemovedEditInteractiveOverlayEventArgs.28Feature.2C_Vertex.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#VertexRemovedEditInteractiveOverlayEventArgs.28Feature.2C_Vertex.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#Equals.28Object.29</a>
Return Type | Description |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#GetHashCode.28.29</a>
Int32<!– System.Int32 –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#GetType.28.29</a>
Type<!– System.Type –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#ToString.28.29</a>
String<!– System.String –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#Finalize.28.29</a>
Void<!– System.Void –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#AffectedVertexFeature” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#AffectedVertexFeature</a>
Return Type |
Feature<!– ThinkGeo.MapSuite.Core.Feature –> |
<!– ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#RemovedVertex” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs#RemovedVertex</a>
Return Type |
Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> |
