<!– Class –> Provides data for the VertexAdding. event.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs</a>
*System.Object System.EventArgs *ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs
VertexAddingTrackInteractiveOverlayEventArgs | Constructor of VertexAddingTrackInteractiveOverlayEventArgs class. | ||
VertexAddingTrackInteractiveOverlayEventArgs | Vertex, Feature, Boolean | Constructor of VertexAddingTrackInteractiveOverlayEventArgs class. |
AddingVertex | Vertex | Gets or sets the feature to be used to add vertex on when tracking shape. | |
AffectedFeature | Feature | Gets or sets the Feature to be used to add vertex to. | |
Cancel | Boolean | Gets or sets the action to be canceled or not. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs#VertexAddingTrackInteractiveOverlayEventArgs.28Vertex.2C_Feature.2C_Boolean.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs#VertexAddingTrackInteractiveOverlayEventArgs.28Vertex.2C_Feature.2C_Boolean.29</a>
| addingVertex | Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> | This parameter specified the vertex is going to be added. |
| affectedFeature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This parameter specified the feature to be used to add vertex on when tracking shape. |
| cancel | Boolean<!– System.Boolean –> | This parameter specified the cancel property. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs#AddingVertex” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs#AddingVertex</a>
<!– ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs#AffectedFeature” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs#AffectedFeature</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs#Cancel” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs#Cancel</a>
