thinkgeo.mapsuite.wpfdesktopedition.maptools
ThinkGeo.MapSuite.WpfDesktopEdition.MapTools
Contains the different map tools as properties and acts as an entrance for setting these map controls.
MapTools()
Constructor of MapTools class.
MapTools(WpfMap)
  • wpfMap
    • Type:WpfMap
    • Description:A WpfMap object that all map tools in this object is based on.
Refresh()
Refreshes all the map tools objects maintaining in the MapTools object.
GetKeys()
  • Type:Collection<String>
Add(String,MapTool)
  • key
  • item
Add(MapTool)
  • item
Insert(Int32,MapTool)
  • index
  • item
Insert(Int32,String,MapTool)
  • index
  • key
  • item
Remove(String)
  • key
MoveUp(Int32)
  • index
MoveUp(String)
  • key
MoveUp(MapTool)
  • item
MoveDown(Int32)
  • index
MoveDown(String)
  • key
MoveDown(MapTool)
  • item
MoveToTop(Int32)
  • index
MoveToTop(String)
  • key
MoveToTop(MapTool)
  • item
MoveToBottom(Int32)
  • index
MoveToBottom(String)
  • key
MoveToBottom(MapTool)
  • item
MoveTo(Int32,Int32)
  • fromIndex
  • toIndex
MoveTo(String,Int32)
  • key
  • toIndex
MoveTo(MapTool,Int32)
  • item
  • toIndex
Contains(String)
  • key
Add(MapTool)
  • item
Clear()
CopyTo(MapTool[],Int32)
  • index
Contains(MapTool)
  • item
GetEnumerator()
  • Type:IEnumerator<MapTool>
IndexOf(MapTool)
  • item
  • index
  • item
Remove(MapTool)
  • item
RemoveAt(Int32)
  • index
OnInserting(InsertingGeoCollectionEventArgs)
OnInserted(InsertedGeoCollectionEventArgs)
OnRemoving(RemovingGeoCollectionEventArgs)
OnRemoved(RemovedGeoCollectionEventArgs)
OnAdding(AddingGeoCollectionEventArgs)
OnAdded(AddedGeoCollectionEventArgs)
OnClearingItems(ClearingItemsGeoCollectionEventArgs)
OnClearedItems(ClearedItemsGeoCollectionEventArgs)
InsertItem(Int32,MapTool)
  • index
  • item
RemoveItem(Int32)
  • index
ClearItems()
SetItem(Int32,MapTool)
  • index
  • item
OnCollectionChanged(NotifyCollectionChangedEventArgs)
  • e
    • Type:NotifyCollectionChangedEventArgs
OnPropertyChanged(PropertyChangedEventArgs)
  • e
    • Type:PropertyChangedEventArgs
Logo
Gets a shortcut of LogoMapTool object.
MouseCoordinate
Gets a shortcut of MouseCoordinate object.
PanZoomBar
Gets a shortcut of PanZoomBar object.
ScaleLine
Gets a shortcut of ScaleLine object.
Item
Count
Item
Items
Inserting N/A
Event Arguments:InsertingGeoCollectionEventArgs
Inserted N/A
Event Arguments:InsertedGeoCollectionEventArgs
Removing N/A
Event Arguments:RemovingGeoCollectionEventArgs
Removed N/A
Event Arguments:RemovedGeoCollectionEventArgs
Adding N/A
Event Arguments:AddingGeoCollectionEventArgs
Added N/A
Event Arguments:AddedGeoCollectionEventArgs
ClearingItems N/A
Event Arguments:ClearingItemsGeoCollectionEventArgs
ClearedItems N/A
Event Arguments:ClearedItemsGeoCollectionEventArgs
CollectionChanged N/A
Event Arguments:
PropertyChanged N/A
Event Arguments:
thinkgeo.mapsuite.wpfdesktopedition.maptools.1442545996.txt.gz · Last modified: 2015/09/18 03:13 by admin
