<!– Class –> Provides data for the MapMouseDoubleClick event.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs</a>
*System.Object System.EventArgs *ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs
MapMouseDoubleClickInteractiveOverlayEventArgs | Constructor of MapMouseDoubleClickInteractiveOverlayEventArgs class. | ||
MapMouseDoubleClickInteractiveOverlayEventArgs | InteractionArguments | Constructor of MapMouseDoubleClickInteractiveOverlayEventArgs class. |
InteractionArguments | InteractionArguments | This property gets the interaction auguments for the event args. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#MapMouseDoubleClickInteractiveOverlayEventArgs.28InteractionArguments.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#MapMouseDoubleClickInteractiveOverlayEventArgs.28InteractionArguments.29</a>
| interactionArguments | InteractionArguments<!– ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments –> | This parameter specified the interaction auguments to construct the class. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#MemberwiseClone.28.29</a>
<!– ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs –> Go Back
