thinkgeo.mapsuite.wpfdesktopedition.backgroundoverlay
ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay
This class inherits from the Overlay abstract class. The specified overlay specifies the background information of the MapControl.
    • ThinkGeo.MapSuite.WpfDesktopEdition.Overlay
      • ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay
BackgroundOverlay()
  • Constructor of BackgroundOverlay class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#BackgroundOverlay.28.29
Refresh(IEnumerable<RectangleShape>)
Refresh(TimeSpan)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#Refresh.28TimeSpan.29
  • bufferTime
    • Type:TimeSpan
Refresh(TimeSpan,RequestDrawingBufferTimeType)
  • bufferTime
    • Type:TimeSpan
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#Refresh.28RectangleShape.2C_TimeSpan.29
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
Initialize(MapArguments)
  • This method initializes overlay object.
  • This is a wrapper method for the virtual method InitializeCore.
  • mapArguments
    • Description:This parameter maintains current map information for calculating mechanism.
Refresh(RectangleShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#Refresh.28RectangleShape.29
Refresh()
  • This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles.
  • The difference from Draw() method is that Refresh() method refreshs all the elements while Draw() does not.
Close()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#Close.28.29
Open()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#Open.28.29
Draw(RectangleShape)
  • This method draws the overlay with the provided extent in world coordinate.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#Draw.28RectangleShape.29
  • targetExtent
    • Description:This parameter indicates an extent in world coordinate for drawing the overlay.
Draw(RectangleShape,OverlayRefreshType)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#Draw.28RectangleShape.2C_OverlayRefreshType.29
  • targetExtent
  • refreshType
    • Description:This parameter indicates whether the elements of this overlay needs to be refreshed. For example, TileOverlay is formed by tiles. When panning the map around, the existing tile doesn't need to be redraw, the only thing we need to do is modifying the position of these tiles. On another hand, when click to change the style of the overlay, we need to redraw the tile images to change the appearance. So we need refresh mode.
PanTo(RectangleShape)
  • This method pans the overlay to the provided world extent.
  • Some overlay doesn't need to continously drawing all the tile. For example, MarkerOverlay is formed by markers. When mouse down to pan, the markers don't need to redraw, we can only change its position. When mouse up to end panning, we can redraw the overlay for better performance.
  • targetExtent
    • Description:This parameter is the target world extent for panning.
GetBoundingBox()
  • This method gets a bounding box of the Overlay.
  • This method is the concrete wrapper for the abstract method GetBoundingBoxCore. This method returns the bounding box of the Overlay. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • Description:A RectangleShape indicating the bounding box of this overlay
SaveState()
  • This method saves overlay state to a byte array.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#SaveState.28.29
  • Type:Byte[]
  • Description:A byte array indicates current overlay state.
LoadState(Byte[])
  • This method restore the overlay state back from the specified state.
  • state
    • Type:Byte[]
    • Description:This parameter indicates the state for restore the overlay.
Dispose()
  • This method dispose unmanaged resource used in this class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#Dispose.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#GetType.28.29
DrawCore(RectangleShape,OverlayRefreshType)
  • This method override the DrawCore logic of the Overlay class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#DrawCore.28RectangleShape.2C_OverlayRefreshType.29
  • targetExtent
    • Description:This parameter specifies the extent for drawing this overlay.
  • refreshType
    • Description:This parameter specifies whether this overlay need to be clear and refresh or not.
SaveStateCore()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#SaveStateCore.28.29
  • Type:Byte[]
LoadStateCore(Byte[])
  • state
    • Type:Byte[]
Dispose(Boolean)
  • This method disposes the unmanaged resource used in this overlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#Dispose.28Boolean.29
  • disposing
InitializeCore(MapArguments)
  • When implementing this method, consider initializing the overlay canvas such as setting its z-index, setting current map reference to the CurrentMap property.
  • mapArguments
RefreshCore(RectangleShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#RefreshCore.28RectangleShape.29
RefreshCore()
CloseCore()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#CloseCore.28.29
OpenCore()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#OpenCore.28.29
4hM=(GeoCanvas)
DrawAttributionCore(GeoCanvas)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#DrawAttributionCore.28GeoCanvas.29
OnDrawingAttribution(DrawingAttributionOverlayEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#OnDrawingAttribution.28DrawingAttributionOverlayEventArgs.29
OnDrawnAttribution(DrawnAttributionOverlayEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#OnDrawnAttribution.28DrawnAttributionOverlayEventArgs.29
PanToCore(RectangleShape)
  • targetExtent
OnDrawing(DrawingOverlayEventArgs)
  • This method raises before the overlay is drawing.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#OnDrawing.28DrawingOverlayEventArgs.29
OnDrawn(DrawnOverlayEventArgs)
  • This method raises after the overlay is drawn.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#OnDrawn.28DrawnOverlayEventArgs.29
GetBoundingBoxCore()
  • This method returns the bounding box of the Overlay.
  • Description:This method returns the bounding box of the Overlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#Finalize.28.29
OnRefreshing(OverlayRefreshType)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#MemberwiseClone.28.29
BackgroundBrush
Gets or sets the background brush for the MapControl.
AutoRefreshInterval
  • Type:TimeSpan
Gets or sets the name of this overaly.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#Name
MapArguments
Gets or sets current map information which will be used for calculating mechanism.
OverlayCanvas
Gets or sets the actual canvas which maintains all the visual elements on the overlay.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#OverlayCanvas
  • Type:Canvas
IsBase
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#IsBase
CanRefreshRegion
DrawingExceptionMode
This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing.
IsVisible
Gets or sets if this overlay is visible.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#IsVisible
Attribution
IsEmpty
This property gets if this overlay is empty or not.
This property enhances the performance of the overlay while drawing. If is true, we will skip drawing this overlay and continue drawing the next overlay.
PreviousExtent
Gets or sets the previous exent of the overlay.
3BM=
IsOverlayInitialized
Gets or sets if the overlay canvas is initialized.
Drawing This event raises before the overlay is drawing.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#OnDrawing.28DrawingOverlayEventArgs.29
Event Arguments:DrawingOverlayEventArgs
Drawn This event raises after the overlay is drawn.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.BackgroundOverlay#OnDrawn.28DrawnOverlayEventArgs.29
Event Arguments:DrawnOverlayEventArgs
DrawingAttribution N/A
thinkgeo.mapsuite.wpfdesktopedition.backgroundoverlay.1442911863.txt.gz · Last modified: 2015/09/22 08:51 by admin
