<!– Class –> This is an asynchronous HTTP handler which is used to handle web map services.
*System.Object **ThinkGeo.MapSuite.WmsServerEdition.WmsHandler
WmsHandler | This is the default constructor for the WmsHandler class. |
BeginProcessRequest | HttpContext, AsyncCallback, Object | Initiates an asynchronous call to the HTTP handler. | |
EndProcessRequest | IAsyncResult | Provides an asynchronous process End method when the process ends. | |
ProcessRequest | HttpContext | Enables processing of HTTP Web requests by a custom HttpHandler that implements the System.Web.IHttpHandler interface. | |
GetCapabilities | GetCapabilitiesRequest, HttpContext | The purpose of the GetCapabilities WMS operation is to retrieve general information about the service itself and specific information about the available layers. | |
GetCapabilitiesCore | GetCapabilitiesRequest, HttpContext | The purpose of the GetCapabilities WMS operation is to retrieve general information about the service itself and specific information about the available layers. | |
GetFeatureInfo | GetFeatureInfoRequest, HttpContext | This method implements the WMS GetFeatureInfo operation and returns feature information depending on the request from the client. | |
GetFeatureInfoCore | GetFeatureInfoRequest, HttpContext | This method implements the WMS GetFeatureInfo operation and returns feature information depending on the request from client. | |
GetMap | GetMapRequest, HttpContext | The GetMap WMS operation is designed to produce a map, which is defined as either a pictorial image or a set of graphical elements. | |
GetMapCore | GetMapRequest, HttpContext | The GetMap WMS operation is designed to produce a map, which is defined as either a pictorial image or a set of graphical elements. | |
MemberwiseClone | Object | ||
ProcessRequestCore | HttpContext | This abstract method is called from the concrete public method ProcessRequest. This method processes the request from client. |
IsReusable | Boolean | Gets a value indicating whether another request can use the System.Web.IHttpHandler instance. |
CapabilitiesFilePathName | String | The file path for your capabilites xml document |
| IAsyncResult<!– System.IAsyncResult –> | A System.IAsyncResult that contains information about the status of the process. |
| context | HttpContext<!– System.Web.HttpContext –> | A System.Web.HttpContext object that provides references to intrinsic server objects (for example: Request, Response, Session, and Server) used to service HTTP requests. |
| cb | AsyncCallback<!– System.AsyncCallback –> | The System.AsyncCallback to call when the asynchronous method call is complete. If cb is null, the delegate is not called. |
| extraData | Object<!– System.Object –> | Any extra data needed to process the request. |
<!– ThinkGeo.MapSuite.WmsServerEdition.WmsHandler –> Go Back
| result | IAsyncResult<!– System.IAsyncResult –> | A System.IAsyncResult that contains information about the status of the process. |
| context | HttpContext<!– System.Web.HttpContext –> | A System.Web.HttpContext object that provides references to the intrinsic server objects (for example: Request, Response, Session, and Server) used to service HTTP requests. |
| String<!– System.String –> | This method returns general information about the service itself and specific information about the available layers. |
| getCapabilitiesRequest | GetCapabilitiesRequest<!– ThinkGeo.MapSuite.WmsServerEdition.GetCapabilitiesRequest –> | The RequestInfo object corresponding to the QueryString from the client's request. |
This abstract method is called from the concrete public method GetCapabilities.
This method is the concrete wrapper for the abstract method GetFeatureInfo. The canonical use case for GetFeatureInfo is that a user sees the response of a GetMap request and chooses a point on that map for which to obtain more information. The basic operation provides the ability for a client to specify which pixel is being asked about, which layer(s) should be investigated, and what format the information should be returned in.
| String<!– System.String –> | This method returns feature information depending on the request from the client. |
| getFeatureInfoRequest | GetFeatureInfoRequest<!– ThinkGeo.MapSuite.WmsServerEdition.GetFeatureInfoRequest –> | The RequestInfo object corresponding to the QueryString from the client's request. |
This abstract method is called from the concrete public method GetFeatureInfo. The canonical use case for GetFeatureInfo is that a user sees the response of a GetMap request and chooses a point on that map for which to obtain more information. The basic operation provides the ability for a client to specify which pixel is being asked about, which layer(s) should be investigated, and what format the information should be returned in.
| Bitmap<!– System.Drawing.Bitmap –> | This method returns a pictorial image or a set of graphical elements. |
| getMapRequest | GetMapRequest<!– ThinkGeo.MapSuite.WmsServerEdition.GetMapRequest –> | The RequestInfo object corresponding to the QueryString from the client's request. |
This abstract method is called from the concrete public method GetMap.
