<!– Class –> This class represents the results of a transaction that was processed.
This class holds the results of a transaction. It can tell the users the number of succeeded record and the number of failed records. It also has a dictionary that holds the individual reasons that certain records fails by FeatureId. If you are implementing this class it is important that you provide as much information about the transaction results to your users.
*System.Object **ThinkGeo.MapSuite.WindowsPhoneCore.TransactionResult
TransactionResult | This is the class constructor. | ||
TransactionResult | Int32, Int32, Dictionary<String, String>, TransactionResultStatus | This is the class constructor. |
FailureReasons | Dictionary<String,String> | This property gets and sets the dictionary that contains the reasons for failure. | |
TotalFailureCount | Int32 | This property gets and sets the total number of records that we committed unsuccessfully. | |
TotalSuccessCount | Int32 | This property gets and sets the total number of records that we committed successfully. | |
TransactionResultStatus | TransactionResultStatus | This property gets and sets the result status of the transaction. |
This is the default constructor and is typically not used.
This is the constructor for this class allows you pass in the necessary properties in the class.
| totalSuccessCount | Int32<!– System.Int32 –> | |
| totalFailureCount | Int32<!– System.Int32 –> | |
| failureReasons | Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> | |
| transactionResultStatus | TransactionResultStatus<!– ThinkGeo.MapSuite.WindowsPhoneCore.TransactionResultStatus –> |
If there are failing records we suggest you add the failure reasons to this dictionary. It is also suggested that you use the FeatureId as the key of the Dictionary.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.TransactionResult –> Go Back
This property returns the results of the transaction. If all of the records committed fine then you get a success status. If any of the records fail then you get a failure status though some of the records may have committed.
