thinkgeo.mapsuite.windowsphonecore.transactionresultstatus
ThinkGeo.MapSuite.WindowsPhoneCore.TransactionResultStatus
<!– Enumeration –> This enumeration represents the results from a FeatureSource transaction.
Items
Name Summary
Success This means that each item in the transaction buffer succeeded.
Failure This means that at least one of the items in the transaction buffer failed. It may mean that other record did succeed. This depends on the implementation of the specific FeatureSource.
Cancel This means that the transaction was canceled.
thinkgeo.mapsuite.windowsphonecore.transactionresultstatus.txt · Last modified: 2017/03/16 21:59 (external edit)
