thinkgeo.mapsuite.windowsphonecore.regexmatching
ThinkGeo.MapSuite.WindowsPhoneCore.RegexMatching
<!– Enumeration –> This enumeration defines the matching criteria for regular expression matching.
This is used to determine how much of a string needs to match a regular expression in order to declare it a match for that expression. Sometimes, you only need one part of the string to match in order for the expression to be considered a match; other times you may want the entire string to match.
Items
Name Summary
MatchFirstOnly Only part of the string must match the regular expression.
MatchAll The entire string must match the regular expression.
thinkgeo.mapsuite.windowsphonecore.regexmatching.txt · Last modified: 2017/03/16 21:59 (external edit)
