thinkgeo.mapsuite.windowsphonecore.progressdrawinggeocanvascanceleventargs
ThinkGeo.MapSuite.WindowsPhoneCore.ProgressDrawingGeoCanvasCancelEventArgs
<!– Class –>
*System.Object System.EventArgs *System.ComponentModel.CancelEventArgs ThinkGeo.MapSuite.WindowsPhoneCore.ProgressDrawingGeoCanvasCancelEventArgs
Public MethodProgressDrawingGeoCanvasCancelEventArgs
Public MethodGetType Object
Public MethodToString Object
Public PropertyCancel Boolean CancelEventArgs
ProgressDrawingGeoCanvasCancelEventArgs()
Name Type Description
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
Cancel
Return Type
<!– System.ComponentModel.CancelEventArgs –> Go Back
thinkgeo.mapsuite.windowsphonecore.progressdrawinggeocanvascanceleventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
