<!– Class –> This class represents the advanced drawing options for point styles.
This class allows you to set the CustomBrush. This enables you to use custom brushes to achieve effects such as linear gradients and bitmap fills.
*System.Object **ThinkGeo.MapSuite.WindowsPhoneCore.PointStyleAdvanced
PointStyleAdvanced | This is the default constructor for the class. |
CustomBrush | GeoBrush | This property allows you to get and set a custom brush. |
This allows you to use custom brushes to achieve effects such as linear gradients and bitmap fills. If you use any brush besides the SolidBrush, you would set it in this property.
| GeoBrush<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoBrush –> |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointStyleAdvanced –> Go Back
