thinkgeo.mapsuite.windowsphonecore.mapsuitetilematrix
ThinkGeo.MapSuite.WindowsPhoneCore.MapSuiteTileMatrix
<!– Class –> This class defines the TileMatrix system used in MapSuite component.
This MapSuite Tile Matrix system is the TileMatrix system designed for use both in Desktop Edition and Web Edition.
Public MethodMapSuiteTileMatrix Double This is the constructor by passing the scale.
Public MethodMapSuiteTileMatrix Double, Int32, Int32, GeographyUnit This is the constructor for the class.
Public MethodMapSuiteTileMatrix Double, Int32, Int32, GeographyUnit, RectangleShape This is the constructor for the class.
Public MethodMapSuiteTileMatrix Double, Int32, Int32, GeographyUnit, PointShape, Int64, Int64 This is the constructor for the class.
Public MethodMapSuiteTileMatrix String, Double, Int32, Int32, GeographyUnit, RectangleShape This is the constructor for the class.
Public MethodMapSuiteTileMatrix String, Double, Int32, Int32, GeographyUnit, PointShape, Int64, Int64 This is the constructor for the class.
Protected MethodGetResolutionFromScale Double TileMatrix(overriden) This method will get resolution from scale and can be overridden.
Protected MethodSetMatrix String, Double, Double, PointShape, MatrixReferenceCorner, Int64, Int64 Matrix
Protected MethodSetMatrix Double, Double Matrix
Protected MethodSetMatrix String, Double, Double, RectangleShape, MatrixReferenceCorner Matrix
MapSuiteTileMatrix(Double)
If you use this constructor, all other properties are used their default values.
Name Type Description
scale Double<!– System.Double –> This parameter specifies the target scale to set the Matrix.
Go Back
MapSuiteTileMatrix(Double, Int32, Int32, GeographyUnit)
Overloads
This is the commonly used constructor for the class.
tileWidth Int32<!– System.Int32 –> This parameter specifies the tile width(in decimalDegrees) to set the Matrix.
tileHeight Int32<!– System.Int32 –> This parameter specifies the tile height(in decimalDegrees) to set the Matrix.
boundingBoxUnit GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> This parameter specifies the boundingBox Unit to set the Matrix.
Go Back
MapSuiteTileMatrix(Double, Int32, Int32, GeographyUnit, RectangleShape)
Overloads
boundingBox RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This parameter specifies the bounding box to set the Matrix.
Go Back
MapSuiteTileMatrix(Double, Int32, Int32, GeographyUnit, PointShape, Int64, Int64)
Overloads
referencePoint PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> This parameter specifies the reference point location to set the Matrix.
rowCount Int64<!– System.Int64 –> This parameter specifies the row count to set the Matrix.
columnCount Int64<!– System.Int64 –> This parameter specifies the column count to set the Matrix.
Go Back
MapSuiteTileMatrix(String, Double, Int32, Int32, GeographyUnit, RectangleShape)
Overloads
id String<!– System.String –> This parameter specifies the id to set the Matrix.
Go Back
MapSuiteTileMatrix(String, Double, Int32, Int32, GeographyUnit, PointShape, Int64, Int64)
Overloads
Go Back
Return Type Description
Boolean<!– System.Boolean –>
GetAllCells()
Collection<TileMatrixCell><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.TileMatrixCell} –>
<!– ThinkGeo.MapSuite.WindowsPhoneCore.Matrix –> Go Back
GetCell(Int64, Int64)
Get the cell by passing a specified row and column.
TileMatrixCell<!– ThinkGeo.MapSuite.WindowsPhoneCore.TileMatrixCell –> The returning cell by specified the row and column.
row Int64<!– System.Int64 –> This parameter specifies the row based on 1.
column Int64<!– System.Int64 –> This parameter specifies the row based on 1.
GetCell(PointShape)
intersectingPoint PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –>
GetColumnIndex(PointShape)
GetContainedCells(RectangleShape)
extent RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –>
GetContainedRowColumnRange(RectangleShape)
RowColumnRange<!– ThinkGeo.MapSuite.WindowsPhoneCore.RowColumnRange –>
GetIntersectingCells(RectangleShape)
GetIntersectingRowColumnRange(RectangleShape)
GetRowIndex(PointShape)
Type<!– System.Type –>
Void<!– System.Void –>
GetResolutionFromScale(Double)
Double<!– System.Double –> Returns the resolution corresponding to the passed in scale.
scale Double<!– System.Double –> This parameter specifies the target scale to get resolution from.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.TileMatrix(overriden) –> Go Back
SetMatrix(String, Double, Double, PointShape, MatrixReferenceCorner, Int64, Int64)
cellWidth Double<!– System.Double –>
cellHeight Double<!– System.Double –>
referenceCorner MatrixReferenceCorner<!– ThinkGeo.MapSuite.WindowsPhoneCore.MatrixReferenceCorner –>
SetMatrix(Double, Double)
SetMatrix(String, Double, Double, RectangleShape, MatrixReferenceCorner)
BoundingBox
Return Type
BoundingBoxUnit
Return Type
<!– ThinkGeo.MapSuite.WindowsPhoneCore.TileMatrix –> Go Back
CellHeight
Return Type
CellWidth
Return Type
ColumnCount
Return Type
Id
Return Type
RowCount
Return Type
Scale
Return Type
TileHeight
Return Type
TileWidth
Return Type
thinkgeo.mapsuite.windowsphonecore.mapsuitetilematrix.txt · Last modified: 2017/03/16 21:59 (external edit)
