<!– Structure –> This structure represents the TileMatrixCell which will be used in the TileMatrix system.
*System.ValueType **ThinkGeo.MapSuite.WindowsPhoneCore.TileMatrixCell
TileMatrixCell | Int64, Int64, RectangleShape | This is the constructor used to create a TileMatrixCell. |
Equals | Object | Object(overriden) | This method is an override of the Equals functionality. |
GetHashCode | Object(overriden) | This method is an override of the GetHashCode functionality. | |
ToString | Object(overriden) | This method is an override of the ToString functionality. |
BoundingBox | RectangleShape | This property gets or sets the BoundingBox of the stucture. | |
Column | Int64 | This property gets or sets the Column number of the stucture. | |
Row | Int64 | This property gets or sets the Row number of the stucture. |
| row | Int64<!– System.Int64 –> | This parameter represents the row number of the TileMatrixCell. |
| column | Int64<!– System.Int64 –> | This parameter represents the column number of the TileMatrixCell. |
| boundingBox | RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> | This parameter represents the boundingBox of the TileMatrixCell. |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.TileMatrixCell –> Go Back
