thinkgeo.mapsuite.windowsphonecore.layersdrawneventargs
ThinkGeo.MapSuite.WindowsPhoneCore.LayersDrawnEventArgs
<!– Class –> This is the event arguments class for the LayersDrawn event on the MapEngine class. It is raised after all of the layers are drawn.
This is the event arguments class for the LayersDrawn event on the MapEngine class. It is raised after the layers are drawn. This event allows you to draw something with the canvas after all of the Layers are drawn.
Public MethodLayersDrawnEventArgs This is a constructor for the class.
Public MethodLayersDrawnEventArgs IEnumerable<Layer>, RectangleShape, Object This is a constructor for the class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyLayers IEnumerable<Layer> This property gets and sets the layers that have been drawn.
Public PropertyNativeImage Object This property gets and sets the GeoImage or native image we are drawing on.
Public PropertyWorldExtent RectangleShape This property gets and sets the world extent to draw.
LayersDrawnEventArgs()
Overloads
Name Type Description
Go Back
LayersDrawnEventArgs(IEnumerable<Layer>, RectangleShape, Object)
Overloads
This constructor allows you to set the layers that were drawn, the world extent, and the image you are drawing on.
layers IEnumerable<Layer><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.Layer} –> This parameter is the layers that were drawn.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This parameter is the world extent you are drawing.
nativeImage Object<!– System.Object –> This parameter is the GeoImage or native map image.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
Layers
Return Type
<!– ThinkGeo.MapSuite.WindowsPhoneCore.LayersDrawnEventArgs –> Go Back
NativeImage
Return Type
WorldExtent
Return Type
thinkgeo.mapsuite.windowsphonecore.layersdrawneventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
