thinkgeo.mapsuite.windowsphonecore.layersdrawingeventargs
ThinkGeo.MapSuite.WindowsPhoneCore.LayersDrawingEventArgs
<!– Class –> This is the event arguments class for the LayersDrawing event on the MapEngine class. It is raised before any of the layers are drawn.
This is the event arguments class for the LayersDrawing event on the MapEngine class. It is raised before any of the layers are drawn. This event allows you to cancel, manipulate the Layer, or draw something with the canvas before the Layer draws.
Public MethodLayersDrawingEventArgs This is a constructor for the class.
Public MethodLayersDrawingEventArgs IEnumerable<Layer>, RectangleShape, Object This is a constructor for the class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyCancel Boolean This property gets and sets the value that indicates you want to cancel all of the layers from drawing.
Public PropertyLayers IEnumerable<Layer> This property gets and sets the layers you will be drawing.
Public PropertyNativeImage Object This property gets and sets the GeoImage or native image that we are drawing on.
Public PropertyWorldExtent RectangleShape This property gets and sets the world extent that will be drawn.
LayersDrawingEventArgs()
Overloads
Name Type Description
Go Back
LayersDrawingEventArgs(IEnumerable<Layer>, RectangleShape, Object)
Overloads
This constructor allows you to set the layers to be drawn, the world extent, and the image you are drawing on.
layers IEnumerable<Layer><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.Layer} –> This parameter is the layers that will be drawn.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This parameter is the world extent you are drawing.
nativeImage Object<!– System.Object –> This parameter is the GeoImage or native map image.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
Cancel
Return Type
<!– ThinkGeo.MapSuite.WindowsPhoneCore.LayersDrawingEventArgs –> Go Back
Layers
Return Type
NativeImage
Return Type
WorldExtent
Return Type
thinkgeo.mapsuite.windowsphonecore.layersdrawingeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
