thinkgeo.mapsuite.windowsphonecore.grouplayer
ThinkGeo.MapSuite.WindowsPhoneCore.GroupLayer
<!– Class –> This class represents a Layer backed by a group of layers.
Public MethodGroupLayer This is the default constructor for the class.
Public MethodGroupLayer IEnumerable<Layer> This is a constructor for the class.
Public MethodClose Layer This method closes the Layer and releases any resources it was using.
Public MethodDraw GeoCanvas, Collection<SimpleCandidate> Layer This method draws the Layer.
Public MethodGetBoundingBox Layer This method returns the bounding box of the Layer.
Public MethodGetType Object
Public MethodOpen Layer This method opens the Layer so that it is initialized and ready to use.
Public MethodToString Object
Protected MethodCloseCore Layer(overriden) This method closes the FeatureSource and releases any resources it was using.
Protected MethodDrawCore GeoCanvas, Collection<SimpleCandidate> Layer(overriden) This method draws the Layer.
Protected MethodDrawException GeoCanvas, Exception Layer This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
Protected MethodDrawExceptionCore GeoCanvas, Exception Layer This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
Protected MethodGetBoundingBoxCore Layer(overriden) This method returns the bounding box of the Layer.
Protected MethodOnDrawingProgressChanged DrawingProgressChangedEventArgs Layer
Protected MethodOpenCore Layer(overriden) This method opens the Layer so that it is initialized and ready to use.
Public PropertyDrawingExceptionMode DrawingExceptionMode Layer Gets or sets the DrawExcpetionMode when exception happens.
Public PropertyDrawingTime TimeSpan Layer This property gets the last drawing time for the layer.
Public PropertyHasBoundingBox Boolean Layer(overriden) This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In GroupLayer, we override this API and mark it as true.
Public PropertyIsOpen Boolean Layer This property returns true if the Layer is open and false if it is not.
Public PropertyIsVisible Boolean Layer This property gets and set the visible state of the layer.
Public PropertyLayers GeoCollection<Layer> This property gets the layers you want to use.
Public PropertyName String Layer This property gets and sets the name for the layer.
Protected PropertyIsOpenCore Boolean Layer This property returns true if the Layer is open and false if it is not.
Public EventDrawingProgressChanged DrawingProgressChangedEventArgs Layer
GroupLayer()
Overloads
Name Type Description
Go Back
GroupLayer(IEnumerable<Layer>)
Overloads
This constructor allows you to provide the path and filename information for the group.
layers IEnumerable<Layer><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.Layer} –> This parameter represents the layers in this class that you want to use.
Go Back
Close()
Return Type Description
Void<!– System.Void –>
<!– ThinkGeo.MapSuite.WindowsPhoneCore.Layer –> Go Back
Draw(GeoCanvas, Collection<SimpleCandidate>)
canvas GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> This parameter is the canvas object or a GeoImage to draw on.
labelsInAllLayers Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.SimpleCandidate} –> This parameter represents the labels used for collision detection and duplication checking.
Boolean<!– System.Boolean –>
GetBoundingBox()
RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This method returns the bounding box of the Layer.
Int32<!– System.Int32 –>
Type<!– System.Type –>
Open()
String<!– System.String –>
CloseCore()
If you override the Core version of this method, it is recommended that you take the following things into account: This method may be called multiple times, so we suggest you write the method so that that a call to a closed Layer is ignored and does not generate an error. We also suggest that in the Close you free all resources that have been opened. Remember that the object will not be destroyed, but will be re-opened possibly in the near future.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.Layer(overriden) –> Go Back
DrawCore(GeoCanvas, Collection<SimpleCandidate>)
This abstract method is called from the concrete public method Draw. This method draws the representation of the layer based on the extent you provided.
When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
labelsInAllLayers Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.SimpleCandidate} –> This parameter are the labels used for collision detection and duplication checking.
DrawException(GeoCanvas, Exception)
canvas GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> The target canvas to draw the layer.
e Exception<!– System.Exception –> The exception thrown when layer.Draw().
DrawExceptionCore(GeoCanvas, Exception)
GetBoundingBoxCore()
e DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingProgressChangedEventArgs –>
OpenCore()
This abstract method is called from the concrete public method Open. The open method plays an important role, as it is responsible for initializing the Layer. Most methods on the Layer will throw an exception if the state of the Layer is not opened. When the map draws each layer, it will open the layer as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the Layer.
Return Type
DrawingExceptionMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingExceptionMode –>
DrawingTime
Return Type
TimeSpan<!– System.TimeSpan –>
HasBoundingBox
Return Type
IsOpen
Return Type
IsVisible
Return Type
Layers
Return Type
GeoCollection<Layer><!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCollection{ThinkGeo.MapSuite.WindowsPhoneCore.Layer} –>
<!– ThinkGeo.MapSuite.WindowsPhoneCore.GroupLayer –> Go Back
Return Type
IsOpenCore
Return Type
Event Arguments
Event Arguments
NOTOC WindowsPhoneMapSuiteCore ThinkGeo.MapSuite.WindowsPhoneCore UpdateDocumentation
thinkgeo.mapsuite.windowsphonecore.grouplayer.txt · Last modified: 2017/03/16 21:59 (external edit)
