thinkgeo.mapsuite.windowsphonecore.committingtransactioneventargs
ThinkGeo.MapSuite.WindowsPhoneCore.CommittingTransactionEventArgs
<!– Class –> This class represents the parameters passed in through the CommittingTransaction event.
Public MethodCommittingTransactionEventArgs TransactionBuffer This is the default constructor for the event.
Public MethodCommittingTransactionEventArgs This is the constructor of the event arguments.
Public MethodGetType Object
Public MethodToString Object
Public PropertyCancel Boolean This property allows you to cancel the transaction.
Public PropertyTransactionBuffer TransactionBuffer This property returns the transaction buffer that needs to be committed.
CommittingTransactionEventArgs(TransactionBuffer)
Overloads
This is the constructor that allows you to pass in a transaction buffer.
Name Type Description
transactionBuffer TransactionBuffer<!– ThinkGeo.MapSuite.WindowsPhoneCore.TransactionBuffer –> This parameter represents the transaction buffer that needs to be committed.
Go Back
CommittingTransactionEventArgs()
Overloads
This is the default constructor for the event arguments.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
Cancel
Return Type
<!– ThinkGeo.MapSuite.WindowsPhoneCore.CommittingTransactionEventArgs –> Go Back
TransactionBuffer
Return Type
thinkgeo.mapsuite.windowsphonecore.committingtransactioneventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
