thinkgeo.mapsuite.windowsphonecore.transactionbuffer
ThinkGeo.MapSuite.WindowsPhoneCore.TransactionBuffer
<!– Class –> This class represents the holding place for transactions that have not yet been committed.
Public MethodTransactionBuffer This is the class constructor.
Public MethodTransactionBuffer Dictionary<String, Feature>, Collection<String>, Dictionary<String, Feature> This is the class constructor.
Public MethodAddFeature BaseShape, Dictionary<String, String> This method allows you to add a shape into the buffer.
Public MethodAddFeature Feature This method allows you to add InternalFeatures to the transaction buffer.
Public MethodAddFeature BaseShape This method allows you to add a shape into the buffer.
Public MethodClear This method will clear all the items in AddBuffer, EditBuffer and DeleteBuffer.
Public MethodDeleteFeature String This method allows you to add a placeholder to represent a Feature to be deleted.
Public MethodEditFeature BaseShape, Dictionary<String, String> This method allows you to add a shape to be updated.
Public MethodEditFeature BaseShape This method allows you to add a shape to be updated.
Public MethodEditFeature Feature This method allows you to add a Feature to be updated.
Public MethodGetType Object
Public MethodToString Object
Public PropertyAddBuffer Dictionary<String,Feature> This property gets the dictionary buffer that holds InternalFeatures to be added.
Public PropertyDeleteBuffer Collection<String> This property gets the dictionary buffer that holds InternalFeatures to be deleted.
Public PropertyEditBuffer Dictionary<String,Feature> This property gets the dictionary buffer that holds InternalFeatures to be updated.
TransactionBuffer()
Overloads
This is the default constructor and is typically not used.
Name Type Description
Go Back
TransactionBuffer(Dictionary<String, Feature>, Collection<String>, Dictionary<String, Feature>)
Overloads
This is the constructor for this class allows you pass in the necessary properties in the class.
addBuffer Dictionary<String,Feature><!– System.Collections.Generic.Dictionary{System.String,ThinkGeo.MapSuite.WindowsPhoneCore.Feature} –>
deleteBuffer Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –>
editBuffer Dictionary<String,Feature><!– System.Collections.Generic.Dictionary{System.String,ThinkGeo.MapSuite.WindowsPhoneCore.Feature} –>
Go Back
AddFeature(BaseShape, Dictionary<String, String>)
Return Type Description
Void<!– System.Void –>
baseShape BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> This parameter represents the shape to be added.
columnValues Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> This parameter represents the feature value to be added.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.TransactionBuffer –> Go Back
AddFeature(Feature)
feature Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> This parameter represents the Feature you are adding to the transaction buffer.
AddFeature(BaseShape)
Clear()
DeleteFeature(String)
This does not remove a feature from the TransactionBuffer but rather it add a “to be deleted record”. In this way when the TransactionBuffer if processed we know what records need to be deleted.
featureId String<!– System.String –> This parameter represents the unique Id for the specific Feature being passed in.
EditFeature(BaseShape, Dictionary<String, String>)
baseShape BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> This parameter represents the shape to be updated. The shape ID should be the same as the feature you are going to update.
columnValues Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> This parameter represents the feature value to be updated. The shape ID should be the same as the feature you are going to update.
EditFeature(BaseShape)
EditFeature(Feature)
feature Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> This parameter represents the Feature to be updated.
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
AddBuffer
It is recommended that you use this dictionary for reviewing and not for adding new items. The reason is that the Add, Delete and Edit methods to various validation checks. For example if you call the DeleteFeature twice it will handle the case that you really only want to delete the record once. Another example is if you edit a record twice it will replace the existing edit with the new one.
Return Type
DeleteBuffer
Return Type
EditBuffer
Return Type
thinkgeo.mapsuite.windowsphonecore.transactionbuffer.txt · Last modified: 2017/03/16 21:59 (external edit)
