thinkgeo.mapsuite.windowsphonecore.committedtransactioneventargs
ThinkGeo.MapSuite.WindowsPhoneCore.CommittedTransactionEventArgs
<!– Class –> This class represents the parameters passed in through the CommittedTransaction event.
Public MethodCommittedTransactionEventArgs TransactionBuffer This is the constructor of the event arguments.
Public MethodCommittedTransactionEventArgs This is the constructor of the event arguments.
Public MethodGetType Object
Public MethodToString Object
Public PropertyTransactionBuffer TransactionBuffer This property returns the transaction buffer that has been committed.
CommittedTransactionEventArgs(TransactionBuffer)
Overloads
This is the constructor that allows you to pass in a transaction buffer.
Name Type Description
transactionBuffer TransactionBuffer<!– ThinkGeo.MapSuite.WindowsPhoneCore.TransactionBuffer –> This parameter represents the transaction buffer that has been committed.
Go Back
CommittedTransactionEventArgs()
Overloads
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
TransactionBuffer
Return Type
<!– ThinkGeo.MapSuite.WindowsPhoneCore.CommittedTransactionEventArgs –> Go Back
thinkgeo.mapsuite.windowsphonecore.committedtransactioneventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
