<!– Class –> This class represents the parameters passed in through the ClosingFeatureSource event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.WindowsPhoneCore.ClosingFeatureSourceEventArgs
ClosingFeatureSourceEventArgs | This is the default constructor. |
