Represents an Overlay that contains layers.
LayerOverlay(String,Boolean,TileType)
Draw(GeoCanvas,Object,RectangleShape,GeographyUnit)
GenerateCacheImages(ZoomLevel,RectangleShape,GeographyUnit)
GenerateCacheImages(Double,RectangleShape,GeographyUnit)
DrawCore(GeoCanvas,Object,RectangleShape,GeographyUnit)
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#TileWidth
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#TileHeight
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#TransitionEffect
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#LayerOverlay.28String.2C_Boolean.2C_TileType.29
Gets or sets the number of extra rows and colums of tiles on each side that will surround the minimum grid tiles to cover the map. Used only when in MultipleTile mode.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#TileMargin
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#ServerCache
Gets or sets the ClientCache object that contains the configuration for the browser cache of this overlay.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#ClientCache
Gets or sets the format of the image that is sent to the web browser.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#WebImageFormat
Gets or sets the quality of the JPEG image that is sent to the web browser. Valid values are between 1 - 100, inclusive.
The <strong>JpegQuality</strong> property determines the quality of the JPEG image that is sent to the browser if the WebImageFormat is Jpeg. Setting this property to a lower value will reduce the image filesize. The value must be between 1 - 100. The default is 100.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#IsMultiThreadDisabled
Gets a GeoCollection that contains the layers that will draw on the image that is sent to the browser.
The <strong>Layers</strong> property holds all of the layers that are used by the <strong>Draw</strong> method. The Draw method loops through all layers to filter out features and draw with specified styles to the image that will be sent to the browser.
Gets or sets a value that indicates whether the overlay is visible on the map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#IsVisible
Gets or sets a value that indicates whether the overlay wraps at the date line.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#WrapDateline
Gets or sets the name of the overlay, which will display in the OverlaySwitcher.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#Name
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#IsVisibleInOverlaySwitcher
Gets or sets a value that indicates whether the overlay is a base overlay.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#IsBaseOverlay
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#Id
Gets or sets the time interval in which the MarkerOverlay refreshes itself.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#AutoRefreshInterval
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#Attribution
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#OverlayType
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#ExtraParameter
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#GetBaseEpsgProjection.28.29
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#HasTickEvent
Tick
Occurs when the number of milliseconds specified in the AutoRefreshInterval property has elapsed and the page is posted to the server.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#OnTick.28EventArgs.29
Event Arguments:EventArgs
