thinkgeo.mapsuite.webapiedition.overlay
ThinkGeo.MapSuite.WebApiEdition.Overlay
Overlay()
Overlay(String)
  • id
Overlay(BitmapTileCache)
Overlay(String,BitmapTileCache)
  • id
Draw(GeoCanvas)
DrawCore(GeoCanvas)
  • This method will draw on the canvas when an exception occurs during the drawing process.
  • geoCanvas
    • Type:GeoCanvas
    • Description:This parameter is the canvas object to draw on.
  • e
    • Type:Exception
    • Description:This parameter is the exception that is occurring.
  • This method is the Core method of DrawException, which can be overridden if you want to change its logic. This method will draw on the canvas when an exception occurs during drawing process.
  • geoCanvas
    • Type:GeoCanvas
  • e
    • Type:Exception
OnDrawing(DrawingOverlayEventArgs)
  • This event will be fired before Overlay is drawn.
OnDrawn(DrawnOverlayEventArgs)
  • This event will be fired after Overlay is drawn.
Id
IsVisible
DrawingExceptionMode
TileCache
Drawing This event raises before the overlay is drawing.
Event Arguments:DrawingOverlayEventArgs
Drawn This event raises after the overlay is drawn.
Event Arguments:DrawnOverlayEventArgs
thinkgeo.mapsuite.webapiedition.overlay.txt · Last modified: 2017/03/16 21:59 (external edit)
