thinkgeo.mapsuite.webapiedition.drawnoverlayeventargs
ThinkGeo.MapSuite.WebApiEdition.DrawnOverlayEventArgs
This is the event arguments for the LayersDrawn event on the GeoImageApiController class. It is raised after the Layers has been drawn.
      • ThinkGeo.MapSuite.WebApiEdition.DrawnOverlayEventArgs
DrawnOverlayEventArgs()
  • This is the default constructor. If you use this constructor then you need to set the required properties manually.
DrawnOverlayEventArgs(GeoCanvas)
  • None
  • geoCanvas
    • Type:GeoCanvas
    • Description:This parameter is the GeoCanvas that have drawn.
GeoCanvas
This property gets and sets the GeoCanvas we are drawing on.
thinkgeo.mapsuite.webapiedition.drawnoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
