<!– Class –> Provides data for the TrackEnding. event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.SilverlightEdition.TrackEndingTrackInteractiveOverlayEventArgs
TrackEndingTrackInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
TrackEndingTrackInteractiveOverlayEventArgs | BaseShape, Boolean | This is the commonly used constructor. |
| shape | BaseShape<!– ThinkGeo.MapSuite.SilverlightCore.BaseShape –> | This parameter specified the shape to be tracking out. |
| cancel | Boolean<!– System.Boolean –> | This parameter specified the cancel property. |
<!– ThinkGeo.MapSuite.SilverlightEdition.TrackEndingTrackInteractiveOverlayEventArgs –> Go Back
This property gets or sets the shape to be tracking out.
