<!– Class –> This class represents a panel in the upper right corner on the map which contains a list of map overlays that added in OverlaySwitcher Overlay collection.
The OverlaySwitcher is a panel that contains a list of overlays and provides you with a means to manage the overlays in the map. You can show or hide an overlay by clicking the checkbox beside its name. You can choose an overlay as the current base overlay by clicking the radio button beside it. Setting the <strong>Enabled</strong> property to true will display this panel on the map.
*System.Object System.Windows.DependencyObject *System.Windows.UIElement System.Windows.FrameworkElement *System.Windows.Controls.Control ThinkGeo.MapSuite.SilverlightEdition.MapTool *ThinkGeo.MapSuite.SilverlightEdition.OverlaySwitcherMapTool
OverlaySwitcherMapTool | This is the constructor of OverlaySwitcherMapTool class. | ||
OverlaySwitcherMapTool | Map, Boolean | This is the constructor of OverlaySwitcherMapTool class. |
AddHandler | RoutedEvent, Delegate, Boolean | UIElement | |
ApplyTemplate | Control | ||
Arrange | Rect | UIElement | |
CaptureMouse | UIElement | ||
CheckAccess | DependencyObject | ||
ClearValue | DependencyProperty | DependencyObject | |
FindName | String | FrameworkElement | |
Focus | Control | ||
GetAnimationBaseValue | DependencyProperty | DependencyObject | |
GetBindingExpression | DependencyProperty | FrameworkElement | |
GetValue | DependencyProperty | DependencyObject | |
InvalidateArrange | UIElement | ||
InvalidateMeasure | UIElement | ||
Measure | Size | UIElement | |
OnApplyTemplate | FrameworkElement(overriden) | When overridden in a derived class, is invoked whenever application code or internal processes (such as a rebuilding layout pass) call System.Windows.Controls.Control.ApplyTemplate(). | |
ReadLocalValue | DependencyProperty | DependencyObject | |
Refresh | This method refreshes all the overlay names in OverlaySwitcherMapTool. | ||
ReleaseMouseCapture | UIElement | ||
RemoveHandler | RoutedEvent, Delegate | UIElement | |
SetBinding | DependencyProperty, Binding | FrameworkElement | |
SetValue | DependencyProperty, Object | DependencyObject | |
ToString | Object | ||
TransformToVisual | UIElement | UIElement | |
UpdateLayout | UIElement |
ArrangeOverride | Size | FrameworkElement | |
EnabledChangedCore | Boolean | MapTool(overriden) | This method raises when IsEnabled property changed. |
GetTemplateChild | String | Control | |
MeasureOverride | Size | FrameworkElement | |
MemberwiseClone | Object | ||
OnCreateAutomationPeer | UIElement | ||
OnGotFocus | RoutedEventArgs | Control | |
OnKeyDown | KeyEventArgs | Control | |
OnKeyUp | KeyEventArgs | Control | |
OnLostFocus | RoutedEventArgs | Control | |
OnLostMouseCapture | MouseEventArgs | Control | |
OnMouseEnter | MouseEventArgs | Control | |
OnMouseLeave | MouseEventArgs | Control | |
OnMouseLeftButtonDown | MouseButtonEventArgs | Control | |
OnMouseLeftButtonUp | MouseButtonEventArgs | Control | |
OnMouseMove | MouseEventArgs | Control | |
OnMouseWheel | MouseWheelEventArgs | Control |
ActualHeight | Double | FrameworkElement | |
ActualWidth | Double | FrameworkElement | |
Background | Brush | Control | |
BorderBrush | Brush | Control | |
BorderThickness | Thickness | Control | |
CacheMode | CacheMode | UIElement | |
Clip | Geometry | UIElement | |
Cursor | Cursor | FrameworkElement | |
DataContext | Object | FrameworkElement | |
DesiredSize | Size | UIElement | |
Dispatcher | Dispatcher | DependencyObject | |
Effect | Effect | UIElement | |
FontFamily | FontFamily | Control | |
FontSize | Double | Control | |
FontStretch | FontStretch | Control | |
FontStyle | FontStyle | Control | |
FontWeight | FontWeight | Control | |
Foreground | Brush | Control | |
HorizontalAlignment | HorizontalAlignment | FrameworkElement | |
HorizontalContentAlignment | HorizontalAlignment | Control | |
IsEnabled | Boolean | MapTool | Gets or sets a value that turns this map tool on or off. |
IsHitTestVisible | Boolean | UIElement | |
IsTabStop | Boolean | Control | |
Language | XmlLanguage | FrameworkElement | |
Margin | Thickness | FrameworkElement | |
MaxHeight | Double | FrameworkElement | |
MaxWidth | Double | FrameworkElement | |
MinHeight | Double | FrameworkElement | |
MinWidth | Double | FrameworkElement | |
MultipleSelectedOverlays | GeoCollection<Overlay> | Gets a group of overlays displayed in OverlaySwitcherMapTools, In the switch panel, you can turn these overlays visible/invisible by check the buttons in front of them. Only one overlay which radio button is checked can be displayed. | |
Opacity | Double | UIElement | |
OpacityMask | Brush | UIElement | |
Padding | Thickness | Control | |
Parent | DependencyObject | FrameworkElement | |
Projection | Projection | UIElement | |
RenderSize | Size | UIElement | |
RenderTransform | Transform | UIElement | |
RenderTransformOrigin | Point | UIElement | |
Resources | ResourceDictionary | FrameworkElement | |
SingleSelectedOverlays | GeoCollection<Overlay> | Gets a group of overlays displayed in OverlaySwitcherMapTools, In the switch panel, a radio button is infront of every overlays in this group and overlays can switch one by one by check the radio button. Only one overlay which radio button is checked can be displayed. | |
Style | Style | FrameworkElement | |
TabIndex | Int32 | Control | |
TabNavigation | KeyboardNavigationMode | Control | |
Tag | Object | FrameworkElement | |
Template | ControlTemplate | Control | |
Triggers | TriggerCollection | FrameworkElement | |
UseLayoutRounding | Boolean | UIElement | |
VerticalAlignment | VerticalAlignment | FrameworkElement | |
VerticalContentAlignment | VerticalAlignment | Control | |
Visibility | Visibility | UIElement | |
DefaultStyleKey | Object | Control | |
Map | Map | MapTool | Gets or sets current map that the mapTool will be drawn on |
BindingValidationError | ValidationErrorEventArgs | FrameworkElement | |
GotFocus | RoutedEventArgs | UIElement | |
IsEnabledChanged | DependencyPropertyChangedEventArgs | Control | |
KeyDown | KeyEventArgs | UIElement | |
KeyUp | KeyEventArgs | UIElement | |
LayoutUpdated | EventArgs | FrameworkElement | |
Loaded | RoutedEventArgs | FrameworkElement | |
LostFocus | RoutedEventArgs | UIElement | |
LostMouseCapture | MouseEventArgs | UIElement | |
MouseEnter | MouseEventArgs | UIElement | |
MouseLeave | MouseEventArgs | UIElement | |
MouseLeftButtonDown | MouseButtonEventArgs | UIElement | |
MouseLeftButtonUp | MouseButtonEventArgs | UIElement | |
MouseMove | MouseEventArgs | UIElement | |
MouseWheel | MouseWheelEventArgs | UIElement | |
SizeChanged | SizeChangedEventArgs | FrameworkElement |
This is the constructor of <strong>OverlaySwitcherMapTool</strong> class.
| map | Map<!– ThinkGeo.MapSuite.SilverlightEdition.Map –> | A Map value indicating where this map tool will be appended on. |
| isEnabled | Boolean<!– System.Boolean –> | A boolean value indicating whether this map tool is on or off. |
| routedEvent | RoutedEvent<!– System.Windows.RoutedEvent –> | |
| handler | Delegate<!– System.Delegate –> | |
| handledEventsToo | Boolean<!– System.Boolean –> |
<!– System.Windows.UIElement –> Go Back
<!– System.Windows.Controls.Control –> Go Back
| finalRect | Rect<!– System.Windows.Rect –> |
<!– System.Windows.DependencyObject –> Go Back
| dp | DependencyProperty<!– System.Windows.DependencyProperty –> |
| name | String<!– System.String –> |
<!– System.Windows.FrameworkElement –> Go Back
| BindingExpression<!– System.Windows.Data.BindingExpression –> |
| availableSize | Size<!– System.Windows.Size –> |
<!– System.Windows.FrameworkElement(overriden) –> Go Back
This method refreshes all the overlay names in <strong>OverlaySwitcherMapTool</strong>.
<!– ThinkGeo.MapSuite.SilverlightEdition.OverlaySwitcherMapTool –> Go Back
| BindingExpressionBase<!– System.Windows.Data.BindingExpressionBase –> |
| dp | DependencyProperty<!– System.Windows.DependencyProperty –> | |
| binding | Binding<!– System.Windows.Data.Binding –> |
| value | Object<!– System.Object –> |
| GeneralTransform<!– System.Windows.Media.GeneralTransform –> |
| visual | UIElement<!– System.Windows.UIElement –> |
| finalSize | Size<!– System.Windows.Size –> |
| newValue | Boolean<!– System.Boolean –> | A new boolean value of IsEnabled property. |
<!– ThinkGeo.MapSuite.SilverlightEdition.MapTool(overriden) –> Go Back
| DependencyObject<!– System.Windows.DependencyObject –> |
| childName | String<!– System.String –> |
| AutomationPeer<!– System.Windows.Automation.Peers.AutomationPeer –> |
| e | RoutedEventArgs<!– System.Windows.RoutedEventArgs –> |
| e | KeyEventArgs<!– System.Windows.Input.KeyEventArgs –> |
| e | MouseEventArgs<!– System.Windows.Input.MouseEventArgs –> |
| e | MouseButtonEventArgs<!– System.Windows.Input.MouseButtonEventArgs –> |
| e | MouseWheelEventArgs<!– System.Windows.Input.MouseWheelEventArgs –> |
| Brush<!– System.Windows.Media.Brush –> |
| Thickness<!– System.Windows.Thickness –> |
| CacheMode<!– System.Windows.Media.CacheMode –> |
| Geometry<!– System.Windows.Media.Geometry –> |
| Cursor<!– System.Windows.Input.Cursor –> |
| Dispatcher<!– System.Windows.Threading.Dispatcher –> |
| Effect<!– System.Windows.Media.Effects.Effect –> |
| FontFamily<!– System.Windows.Media.FontFamily –> |
| FontStretch<!– System.Windows.FontStretch –> |
| FontStyle<!– System.Windows.FontStyle –> |
| FontWeight<!– System.Windows.FontWeight –> |
| HorizontalAlignment<!– System.Windows.HorizontalAlignment –> |
<!– ThinkGeo.MapSuite.SilverlightEdition.MapTool –> Go Back
| XmlLanguage<!– System.Windows.Markup.XmlLanguage –> |
| GeoCollection<Overlay><!– ThinkGeo.MapSuite.SilverlightCore.GeoCollection{ThinkGeo.MapSuite.SilverlightEdition.Overlay} –> |
| Projection<!– System.Windows.Media.Projection –> |
| Transform<!– System.Windows.Media.Transform –> |
| Point<!– System.Windows.Point –> |
| ResourceDictionary<!– System.Windows.ResourceDictionary –> |
| Style<!– System.Windows.Style –> |
| KeyboardNavigationMode<!– System.Windows.Input.KeyboardNavigationMode –> |
| ControlTemplate<!– System.Windows.Controls.ControlTemplate –> |
| TriggerCollection<!– System.Windows.TriggerCollection –> |
| VerticalAlignment<!– System.Windows.VerticalAlignment –> |
| Visibility<!– System.Windows.Visibility –> |
| Event Arguments |
| ValidationErrorEventArgs<!– System.Windows.Controls.ValidationErrorEventArgs –> |
| Event Arguments |
| Event Arguments |
| DependencyPropertyChangedEventArgs<!– System.Windows.DependencyPropertyChangedEventArgs –> |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| EventArgs<!– System.EventArgs –> |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| SizeChangedEventArgs<!– System.Windows.SizeChangedEventArgs –> |
NOTOC SilverlightEdition ThinkGeo.MapSuite.SilverlightEdition UpdateDocumentation
