Represents the coordinates of the mouse pointer that displays at the lower-right corner of the map.
MouseCoordinateMapTool(Map,MouseCoordinateType)
Initialize an instance of MouseCoordinateMapTool class.
MouseCoordinateMapTool(Map,Boolean,MouseCoordinateType)
Builds the visual tree for the MouseCoordinateMapTool control when a new template is applied.
GetBindingExpression(DependencyProperty)
RemoveHandler(RoutedEvent,Delegate)
ClearValue(DependencyProperty)
GetValueFromBuiltInStyle(DependencyProperty,Object&)
NativeOnLostMouseCapture(MouseEventArgs)
OnManipulationDelta(ManipulationDeltaEventArgs)
OnManipulationCompleted(ManipulationCompletedEventArgs)
RemoveTemplateBinding(FrameworkElement,DependencyProperty)
NotifyDataContextChanged(DataContextChangedEventArgs)
OnBindingValidationError(ValidationErrorEventArgs)
OnAncestorDataContextChanged(DataContextChangedEventArgs)
IsDataContextChangeRelevant(DataContextChangedEventArgs)
OnDataContextChanged(DataContextChangedEventArgs)
SetValueInternal(DependencyProperty,Object,Boolean)
SetValueInternal(DependencyProperty,Object,Boolean,Boolean)
ClearValueInternal(DependencyProperty)
InvalidateStyleBinding(DependencyProperty,Boolean&)
SetValue(DependencyProperty,Matrix)
SetValue(DependencyProperty,Matrix3D)
SetValue(DependencyProperty,Point)
SetValue(DependencyProperty,DependencyObject)
SetValue(DependencyProperty,Int32)
SetValue(DependencyProperty,Boolean)
SetValue(DependencyProperty,Enum)
SetValue(DependencyProperty,Color)
SetValue(DependencyProperty,Double)
SetValue(DependencyProperty,GridLength)
InvalidateProperty(DependencyProperty)
GetOldValue(DependencyProperty,EffectiveValueEntry&)
GetNewValue(DependencyProperty,EffectiveValueEntry&)
SetEffectiveValue(DependencyProperty,EffectiveValueEntry&,Object)
UpdateParentInheritanceContextPropagation()
ClearAnimatedValue(DependencyProperty,Boolean,Object)
OnInheritanceContextChanged(Object,EventArgs)
AddEventListener(DependencyProperty,Delegate)
AddEventListener(DependencyProperty,Delegate,Boolean)
RemoveEventListener(DependencyProperty,Delegate)
UpdateTreeParent(IManagedPeer,IManagedPeer,Boolean,Boolean)
UpdateTreeParentHelper(IManagedPeer,IManagedPeer,Boolean)
IsPropertyLocal(CoreDependencyProperty)
OnParentEnter(IntPtr,UInt32,UInt32,UInt32,UInt32)
The MouseCoordinateType property gives you two options to display the mouse pointer coordinates. One is in the format “Longitude, Latitude” and another is in DMS format (33° 22' 15'').
Event Arguments:GestureEventArgs
