<!– Class –> Represents the coordinates of the mouse pointer that displays at the lower-right corner of the map.
The <strong>MouseCoordinateMapTool</strong> control represents the coordinates where current mouse pointer is. The default coordinates string is in format as “longitude , latitude”, and you can choose to display coordinates in DMS.
*System.Object System.Windows.DependencyObject *System.Windows.UIElement System.Windows.FrameworkElement *System.Windows.Controls.Control ThinkGeo.MapSuite.SilverlightEdition.MapTool *ThinkGeo.MapSuite.SilverlightEdition.MouseCoordinateMapTool
MouseCoordinateMapTool | Initialize an instance of MouseCoordinateMapTool class. | ||
MouseCoordinateMapTool | Map | Initialize an instance of MouseCoordinateMapTool class. | |
MouseCoordinateMapTool | Map, MouseCoordinateType | Initialize an instance of MouseCoordinateMapTool class. | |
MouseCoordinateMapTool | Map, Boolean, MouseCoordinateType | Initialize an instance of MouseCoordinateMapTool class. |
AddHandler | RoutedEvent, Delegate, Boolean | UIElement | |
ApplyTemplate | Control | ||
Arrange | Rect | UIElement | |
CaptureMouse | UIElement | ||
CheckAccess | DependencyObject | ||
ClearValue | DependencyProperty | DependencyObject | |
FindName | String | FrameworkElement | |
Focus | Control | ||
GetAnimationBaseValue | DependencyProperty | DependencyObject | |
GetBindingExpression | DependencyProperty | FrameworkElement | |
GetValue | DependencyProperty | DependencyObject | |
InvalidateArrange | UIElement | ||
InvalidateMeasure | UIElement | ||
Measure | Size | UIElement | |
OnApplyTemplate | FrameworkElement(overriden) | Builds the visual tree for the MouseCoordinateMapTool control when a new template is applied. | |
ReadLocalValue | DependencyProperty | DependencyObject | |
ReleaseMouseCapture | UIElement | ||
RemoveHandler | RoutedEvent, Delegate | UIElement | |
SetBinding | DependencyProperty, Binding | FrameworkElement | |
SetValue | DependencyProperty, Object | DependencyObject | |
ToString | Object | ||
TransformToVisual | UIElement | UIElement | |
UpdateLayout | UIElement |
ArrangeOverride | Size | FrameworkElement | |
EnabledChangedCore | Boolean | MapTool(overriden) | Occcurs when the Enabled property changes |
GetTemplateChild | String | Control | |
MeasureOverride | Size | FrameworkElement | |
MemberwiseClone | Object | ||
OnCreateAutomationPeer | UIElement | ||
OnGotFocus | RoutedEventArgs | Control | |
OnKeyDown | KeyEventArgs | Control | |
OnKeyUp | KeyEventArgs | Control | |
OnLostFocus | RoutedEventArgs | Control | |
OnLostMouseCapture | MouseEventArgs | Control | |
OnMouseEnter | MouseEventArgs | Control | |
OnMouseLeave | MouseEventArgs | Control | |
OnMouseLeftButtonDown | MouseButtonEventArgs | Control | |
OnMouseLeftButtonUp | MouseButtonEventArgs | Control | |
OnMouseMove | MouseEventArgs | Control | |
OnMouseWheel | MouseWheelEventArgs | Control |
ActualHeight | Double | FrameworkElement | |
ActualWidth | Double | FrameworkElement | |
Background | Brush | Control | |
BorderBrush | Brush | Control | |
BorderThickness | Thickness | Control | |
CacheMode | CacheMode | UIElement | |
Clip | Geometry | UIElement | |
Cursor | Cursor | FrameworkElement | |
DataContext | Object | FrameworkElement | |
DesiredSize | Size | UIElement | |
Dispatcher | Dispatcher | DependencyObject | |
Effect | Effect | UIElement | |
FontFamily | FontFamily | Control | |
FontSize | Double | Control | |
FontStretch | FontStretch | Control | |
FontStyle | FontStyle | Control | |
FontWeight | FontWeight | Control | |
Foreground | Brush | Control | |
HorizontalAlignment | HorizontalAlignment | FrameworkElement | |
HorizontalContentAlignment | HorizontalAlignment | Control | |
IsEnabled | Boolean | MapTool | Gets or sets a value that turns this map tool on or off. |
IsHitTestVisible | Boolean | UIElement | |
IsTabStop | Boolean | Control | |
Language | XmlLanguage | FrameworkElement | |
Margin | Thickness | FrameworkElement | |
MaxHeight | Double | FrameworkElement | |
MaxWidth | Double | FrameworkElement | |
MinHeight | Double | FrameworkElement | |
MinWidth | Double | FrameworkElement | |
MouseCoordinateType | MouseCoordinateType | Gets or sets the format that the mouse coordinates will display. | |
Opacity | Double | UIElement | |
OpacityMask | Brush | UIElement | |
Padding | Thickness | Control | |
Parent | DependencyObject | FrameworkElement | |
Projection | Projection | UIElement | |
RenderSize | Size | UIElement | |
RenderTransform | Transform | UIElement | |
RenderTransformOrigin | Point | UIElement | |
Resources | ResourceDictionary | FrameworkElement | |
Style | Style | FrameworkElement | |
TabIndex | Int32 | Control | |
TabNavigation | KeyboardNavigationMode | Control | |
Tag | Object | FrameworkElement | |
Template | ControlTemplate | Control | |
Triggers | TriggerCollection | FrameworkElement | |
UseLayoutRounding | Boolean | UIElement | |
VerticalAlignment | VerticalAlignment | FrameworkElement | |
VerticalContentAlignment | VerticalAlignment | Control | |
Visibility | Visibility | UIElement | |
DefaultStyleKey | Object | Control | |
Map | Map | MapTool | Gets or sets current map that the mapTool will be drawn on |
BindingValidationError | ValidationErrorEventArgs | FrameworkElement | |
GotFocus | RoutedEventArgs | UIElement | |
IsEnabledChanged | DependencyPropertyChangedEventArgs | Control | |
KeyDown | KeyEventArgs | UIElement | |
KeyUp | KeyEventArgs | UIElement | |
LayoutUpdated | EventArgs | FrameworkElement | |
Loaded | RoutedEventArgs | FrameworkElement | |
LostFocus | RoutedEventArgs | UIElement | |
LostMouseCapture | MouseEventArgs | UIElement | |
MouseEnter | MouseEventArgs | UIElement | |
MouseLeave | MouseEventArgs | UIElement | |
MouseLeftButtonDown | MouseButtonEventArgs | UIElement | |
MouseLeftButtonUp | MouseButtonEventArgs | UIElement | |
MouseMove | MouseEventArgs | UIElement | |
MouseWheel | MouseWheelEventArgs | UIElement | |
SizeChanged | SizeChangedEventArgs | FrameworkElement |
Initialize an instance of the MouseCoordinateMapTool class.
| map | Map<!– ThinkGeo.MapSuite.SilverlightEdition.Map –> | Specifys the map that the MouseCoordinateMapTool will be drawn on |
| mouseCoordinateType | MouseCoordinateType<!– ThinkGeo.MapSuite.SilverlightEdition.MouseCoordinateType –> | Specifys the type that determines the format of the coordinates string |
| isEnabled | Boolean<!– System.Boolean –> | Indicates whether the user can interact with the control |
| routedEvent | RoutedEvent<!– System.Windows.RoutedEvent –> | |
| handler | Delegate<!– System.Delegate –> | |
| handledEventsToo | Boolean<!– System.Boolean –> |
<!– System.Windows.UIElement –> Go Back
<!– System.Windows.Controls.Control –> Go Back
| finalRect | Rect<!– System.Windows.Rect –> |
<!– System.Windows.DependencyObject –> Go Back
| dp | DependencyProperty<!– System.Windows.DependencyProperty –> |
| name | String<!– System.String –> |
<!– System.Windows.FrameworkElement –> Go Back
| BindingExpression<!– System.Windows.Data.BindingExpression –> |
| availableSize | Size<!– System.Windows.Size –> |
<!– System.Windows.FrameworkElement(overriden) –> Go Back
| BindingExpressionBase<!– System.Windows.Data.BindingExpressionBase –> |
| dp | DependencyProperty<!– System.Windows.DependencyProperty –> | |
| binding | Binding<!– System.Windows.Data.Binding –> |
| value | Object<!– System.Object –> |
| GeneralTransform<!– System.Windows.Media.GeneralTransform –> |
| visual | UIElement<!– System.Windows.UIElement –> |
| finalSize | Size<!– System.Windows.Size –> |
| newValue | Boolean<!– System.Boolean –> | Indicates whether the visibility of MapTool is set as Visibility.Visible |
<!– ThinkGeo.MapSuite.SilverlightEdition.MapTool(overriden) –> Go Back
| DependencyObject<!– System.Windows.DependencyObject –> |
| childName | String<!– System.String –> |
| AutomationPeer<!– System.Windows.Automation.Peers.AutomationPeer –> |
| e | RoutedEventArgs<!– System.Windows.RoutedEventArgs –> |
| e | KeyEventArgs<!– System.Windows.Input.KeyEventArgs –> |
| e | MouseEventArgs<!– System.Windows.Input.MouseEventArgs –> |
| e | MouseButtonEventArgs<!– System.Windows.Input.MouseButtonEventArgs –> |
| e | MouseWheelEventArgs<!– System.Windows.Input.MouseWheelEventArgs –> |
| Brush<!– System.Windows.Media.Brush –> |
| Thickness<!– System.Windows.Thickness –> |
| CacheMode<!– System.Windows.Media.CacheMode –> |
| Geometry<!– System.Windows.Media.Geometry –> |
| Cursor<!– System.Windows.Input.Cursor –> |
| Dispatcher<!– System.Windows.Threading.Dispatcher –> |
| Effect<!– System.Windows.Media.Effects.Effect –> |
| FontFamily<!– System.Windows.Media.FontFamily –> |
| FontStretch<!– System.Windows.FontStretch –> |
| FontStyle<!– System.Windows.FontStyle –> |
| FontWeight<!– System.Windows.FontWeight –> |
| HorizontalAlignment<!– System.Windows.HorizontalAlignment –> |
<!– ThinkGeo.MapSuite.SilverlightEdition.MapTool –> Go Back
| XmlLanguage<!– System.Windows.Markup.XmlLanguage –> |
The MouseCoordinateType property gives you two options to display the mouse pointer coordinates. One is in the format “Longitude, Latitude” and another is in DMS format (33° 22' 15). === Return Value === ^ Return Type ^ | MouseCoordinateType<!– ThinkGeo.MapSuite.SilverlightEdition.MouseCoordinateType –> | <!– ThinkGeo.MapSuite.SilverlightEdition.MouseCoordinateMapTool –> Go Back ==== Name ==== === Return Value === ^ Return Type ^ | String<!– System.String –> | <!– System.Windows.FrameworkElement –> Go Back ==== Opacity ==== === Return Value === ^ Return Type ^ | Double<!– System.Double –> | <!– System.Windows.UIElement –> Go Back ==== OpacityMask ==== === Return Value === ^ Return Type ^ | Brush<!– System.Windows.Media.Brush –> | <!– System.Windows.UIElement –> Go Back ==== Padding ==== === Return Value === ^ Return Type ^ | Thickness<!– System.Windows.Thickness –> | <!– System.Windows.Controls.Control –> Go Back ==== Parent ==== === Return Value === ^ Return Type ^ | DependencyObject<!– System.Windows.DependencyObject –> | <!– System.Windows.FrameworkElement –> Go Back ==== Projection ==== === Return Value === ^ Return Type ^ | Projection<!– System.Windows.Media.Projection –> | <!– System.Windows.UIElement –> Go Back ==== RenderSize ==== === Return Value === ^ Return Type ^ | Size<!– System.Windows.Size –> | <!– System.Windows.UIElement –> Go Back ==== RenderTransform ==== === Return Value === ^ Return Type ^ | Transform<!– System.Windows.Media.Transform –> | <!– System.Windows.UIElement –> Go Back ==== RenderTransformOrigin ==== === Return Value === ^ Return Type ^ | Point<!– System.Windows.Point –> | <!– System.Windows.UIElement –> Go Back ==== Resources ==== === Return Value === ^ Return Type ^ | ResourceDictionary<!– System.Windows.ResourceDictionary –> | <!– System.Windows.FrameworkElement –> Go Back ==== Style ==== === Return Value === ^ Return Type ^ | Style<!– System.Windows.Style –> | <!– System.Windows.FrameworkElement –> Go Back ==== TabIndex ==== === Return Value === ^ Return Type ^ | Int32<!– System.Int32 –> | <!– System.Windows.Controls.Control –> Go Back ==== TabNavigation ==== === Return Value === ^ Return Type ^ | KeyboardNavigationMode<!– System.Windows.Input.KeyboardNavigationMode –> | <!– System.Windows.Controls.Control –> Go Back ==== Tag ==== === Return Value === ^ Return Type ^ | Object<!– System.Object –> | <!– System.Windows.FrameworkElement –> Go Back ==== Template ==== === Return Value === ^ Return Type ^ | ControlTemplate<!– System.Windows.Controls.ControlTemplate –> | <!– System.Windows.Controls.Control –> Go Back ==== Triggers ==== === Return Value === ^ Return Type ^ | TriggerCollection<!– System.Windows.TriggerCollection –> | <!– System.Windows.FrameworkElement –> Go Back ==== UseLayoutRounding ==== === Return Value === ^ Return Type ^ | Boolean<!– System.Boolean –> | <!– System.Windows.UIElement –> Go Back ==== VerticalAlignment ==== === Return Value === ^ Return Type ^ | VerticalAlignment<!– System.Windows.VerticalAlignment –> | <!– System.Windows.FrameworkElement –> Go Back ==== VerticalContentAlignment ==== === Return Value === ^ Return Type ^ | VerticalAlignment<!– System.Windows.VerticalAlignment –> | <!– System.Windows.Controls.Control –> Go Back ==== Visibility ==== === Return Value === ^ Return Type ^ | Visibility<!– System.Windows.Visibility –> | <!– System.Windows.UIElement –> Go Back ==== Width ==== === Return Value === ^ Return Type ^ | Double<!– System.Double –> | <!– System.Windows.FrameworkElement –> Go Back ===== Protected Properties ===== ==== DefaultStyleKey ==== === Return Value === ^ Return Type ^ | Object<!– System.Object –> | <!– System.Windows.Controls.Control –> Go Back ==== Map ==== Gets or sets current map that the mapTool will be drawn on === Return Value === ^ Return Type ^ | Map<!– ThinkGeo.MapSuite.SilverlightEdition.Map –> | <!– ThinkGeo.MapSuite.SilverlightEdition.MapTool –> Go Back ===== Public Events ===== ==== BindingValidationError ==== === Event Arguments === ^ Event Arguments ^ | ValidationErrorEventArgs<!– System.Windows.Controls.ValidationErrorEventArgs –> | <!– System.Windows.FrameworkElement –> Go Back ==== GotFocus ==== === Event Arguments === ^ Event Arguments ^ | RoutedEventArgs<!– System.Windows.RoutedEventArgs –> | <!– System.Windows.UIElement –> Go Back ==== IsEnabledChanged ==== === Event Arguments === ^ Event Arguments ^ | DependencyPropertyChangedEventArgs<!– System.Windows.DependencyPropertyChangedEventArgs –> | <!– System.Windows.Controls.Control –> Go Back ==== KeyDown ==== === Event Arguments === ^ Event Arguments ^ | KeyEventArgs<!– System.Windows.Input.KeyEventArgs –> | <!– System.Windows.UIElement –> Go Back ==== KeyUp ==== === Event Arguments === ^ Event Arguments ^ | KeyEventArgs<!– System.Windows.Input.KeyEventArgs –> | <!– System.Windows.UIElement –> Go Back ==== LayoutUpdated ==== === Event Arguments === ^ Event Arguments ^ | EventArgs<!– System.EventArgs –> | <!– System.Windows.FrameworkElement –> Go Back ==== Loaded ==== === Event Arguments === ^ Event Arguments ^ | RoutedEventArgs<!– System.Windows.RoutedEventArgs –> | <!– System.Windows.FrameworkElement –> Go Back ==== LostFocus ==== === Event Arguments === ^ Event Arguments ^ | RoutedEventArgs<!– System.Windows.RoutedEventArgs –> | <!– System.Windows.UIElement –> Go Back ==== LostMouseCapture ==== === Event Arguments === ^ Event Arguments ^ | MouseEventArgs<!– System.Windows.Input.MouseEventArgs –> | <!– System.Windows.UIElement –> Go Back ==== MouseEnter ==== === Event Arguments === ^ Event Arguments ^ | MouseEventArgs<!– System.Windows.Input.MouseEventArgs –> | <!– System.Windows.UIElement –> Go Back ==== MouseLeave ==== === Event Arguments === ^ Event Arguments ^ | MouseEventArgs<!– System.Windows.Input.MouseEventArgs –> | <!– System.Windows.UIElement –> Go Back ==== MouseLeftButtonDown ==== === Event Arguments === ^ Event Arguments ^ | MouseButtonEventArgs<!– System.Windows.Input.MouseButtonEventArgs –> | <!– System.Windows.UIElement –> Go Back ==== MouseLeftButtonUp ==== === Event Arguments === ^ Event Arguments ^ | MouseButtonEventArgs<!– System.Windows.Input.MouseButtonEventArgs –> | <!– System.Windows.UIElement –> Go Back ==== MouseMove ==== === Event Arguments === ^ Event Arguments ^ | MouseEventArgs<!– System.Windows.Input.MouseEventArgs –> | <!– System.Windows.UIElement –> Go Back ==== MouseWheel ==== === Event Arguments === ^ Event Arguments ^ | MouseWheelEventArgs<!– System.Windows.Input.MouseWheelEventArgs –> | <!– System.Windows.UIElement –> Go Back ==== SizeChanged ==== === Event Arguments === ^ Event Arguments ^ | SizeChangedEventArgs<!– System.Windows.SizeChangedEventArgs –> | <!– System.Windows.FrameworkElement –> Go Back NOTOC SilverlightEdition ThinkGeo.MapSuite.SilverlightEdition UpdateDocumentation
