thinkgeo.mapsuite.silverlightedition.maptool
ThinkGeo.MapSuite.SilverlightEdition.MapTool
This abstract class represents the base class of all predefined map tools.
MapTool()
  • Initialize an instance of the MapTool class.
MapTool(Map)
  • map
    • Type:Map
MapTool(Map,Boolean)
  • map
    • Type:Map
  • isEnabled
OnApplyTemplate()
  • Builds the visual tree for the MapTool control when a new template is applied.
Focus()
ApplyTemplate()
FindName(String)
  • name
SetBinding(DependencyProperty,Binding)
  • Type:BindingExpressionBase
  • dp
    • Type:DependencyProperty
  • binding
    • Type:Binding
GetBindingExpression(DependencyProperty)
  • dp
AddHandler(RoutedEvent,Delegate,Boolean)
  • routedEvent
    • Type:RoutedEvent
  • handler
    • Type:Delegate
  • handledEventsToo
RemoveHandler(RoutedEvent,Delegate)
  • routedEvent
    • Type:RoutedEvent
  • handler
    • Type:Delegate
TransformToVisual(UIElement)
  • Type:GeneralTransform
  • visual
    • Type:UIElement
Measure(Size)
  • availableSize
    • Type:Size
Arrange(Rect)
  • finalRect
    • Type:Rect
CaptureMouse()
ReleaseMouseCapture()
InvalidateMeasure()
InvalidateArrange()
UpdateLayout()
CheckAccess()
SetValue(DependencyProperty,Object)
  • dp
  • value
ClearValue(DependencyProperty)
  • dp
ReadLocalValue(DependencyProperty)
  • dp
GetAnimationBaseValue(DependencyProperty)
  • dp
GetValue(DependencyProperty)
  • dp
EnabledChangedCore(Boolean)
  • Occcurs when the Enabled property changes
  • newValue
    • Description:Indicates whether the visibility of MapTool is set as Visibility.Visible
OnDrop(DragEventArgs)
  • e
    • Type:DragEventArgs
NativeMouseMove(MouseEventArgs)
  • e
    • Type:MouseEventArgs
NativeMouseEnter(MouseEventArgs)
  • e
NativeMouseLeave(MouseEventArgs)
  • e
NativeMouseLeftButtonDown(MouseButtonEventArgs)
  • e
    • Type:MouseButtonEventArgs
NativeMouseLeftButtonUp(MouseButtonEventArgs)
  • e
NativeMouseRightButtonDown(MouseButtonEventArgs)
  • e
NativeMouseRightButtonUp(MouseButtonEventArgs)
  • e
NativeMouseWheel(MouseWheelEventArgs)
  • e
    • Type:MouseWheelEventArgs
NativeKeyUp(KeyEventArgs)
  • e
    • Type:KeyEventArgs
NativeKeyDown(KeyEventArgs)
  • e
    • Type:KeyEventArgs
NativeGotFocus(RoutedEventArgs)
  • e
    • Type:RoutedEventArgs
NativeLostFocus(RoutedEventArgs)
  • e
NativeIsEnabledChanged(IsEnabledChangedEventArgs)
  • e
    • Type:IsEnabledChangedEventArgs
GetValueFromBuiltInStyle(DependencyProperty,Object&)
  • property
  • value
    • Type:Object&
NativeOnLostMouseCapture(MouseEventArgs)
  • e
NativeTextInput(TextCompositionEventArgs)
  • e
    • Type:TextCompositionEventArgs
NativeTextInputStart(TextCompositionEventArgs)
  • e
NativeTextInputUpdate(TextCompositionEventArgs)
  • e
NativeDragEnter(DragEventArgs)
  • e
NativeDragLeave(DragEventArgs)
  • e
NativeDragOver(DragEventArgs)
  • e
NativeDrop(DragEventArgs)
  • e
ShowValidationError()
HideValidationError()
UpdateValidationState()
OnManipulationStarted(ManipulationStartedEventArgs)
  • e
    • Type:ManipulationStartedEventArgs
OnManipulationDelta(ManipulationDeltaEventArgs)
  • e
    • Type:ManipulationDeltaEventArgs
OnManipulationCompleted(ManipulationCompletedEventArgs)
  • e
    • Type:ManipulationCompletedEventArgs
OnTap(GestureEventArgs)
  • e
    • Type:GestureEventArgs
OnDoubleTap(GestureEventArgs)
  • e
OnHold(GestureEventArgs)
  • e
GetTemplateChild(String)
  • Type:DependencyObject
  • childName
RemoveTemplateBinding(FrameworkElement,DependencyProperty)
  • target
    • Type:FrameworkElement
  • targetProperty
GoToState(Boolean,String)
  • useTransitions
  • stateName
OnMouseMove(MouseEventArgs)
  • e
OnMouseEnter(MouseEventArgs)
  • e
OnMouseLeave(MouseEventArgs)
  • e
OnMouseLeftButtonDown(MouseButtonEventArgs)
  • e
OnMouseLeftButtonUp(MouseButtonEventArgs)
  • e
OnMouseRightButtonDown(MouseButtonEventArgs)
  • e
OnMouseRightButtonUp(MouseButtonEventArgs)
  • e
OnMouseWheel(MouseWheelEventArgs)
  • e
OnKeyUp(KeyEventArgs)
  • e
    • Type:KeyEventArgs
OnKeyDown(KeyEventArgs)
  • e
    • Type:KeyEventArgs
OnGotFocus(RoutedEventArgs)
  • e
OnLostFocus(RoutedEventArgs)
  • e
OnIsEnabledChanged(IsEnabledChangedEventArgs)
  • e
  • e
OnTextInput(TextCompositionEventArgs)
  • e
OnTextInputStart(TextCompositionEventArgs)
  • e
OnTextInputUpdate(TextCompositionEventArgs)
  • e
OnDragEnter(DragEventArgs)
  • e
OnDragLeave(DragEventArgs)
  • e
OnDragOver(DragEventArgs)
  • e
ApplyTemplateInternal()
GetValueInternal(DependencyProperty)
  • dp
MeasureOverride(Size)
  • Type:Size
  • availableSize
    • Type:Size
ArrangeOverride(Size)
  • Type:Size
  • finalSize
    • Type:Size
OnTreeParentUpdated(DependencyObject,Boolean)
  • newParent
  • bIsNewParentAlive
NotifyDataContextChanged(DataContextChangedEventArgs)
  • e
    • Type:DataContextChangedEventArgs
OnBindingValidationError(ValidationErrorEventArgs)
  • args
    • Type:ValidationErrorEventArgs
CalculateBubblePath()
  • Type:List<FrameworkElement>
RaiseBindingValidationError(ValidationErrorEventArgs)
  • args
OnSizeChanged(Object,SizeChangedEventArgs)
  • sender
  • e
    • Type:SizeChangedEventArgs
OnAncestorDataContextChanged(DataContextChangedEventArgs)
  • e
IsDataContextChangeRelevant(DataContextChangedEventArgs)
  • e
OnDataContextChanged(DataContextChangedEventArgs)
  • e
OnPropertyChanged(DependencyProperty)
  • dp
GetValueFromStyle(DependencyProperty,Object&)
  • property
  • value
    • Type:Object&
HasFocus()
FindNameInPage(String,Boolean)
  • name
  • calledFromUserControl
GetPlainText()
HitTest(Point)
  • Type:IEnumerable<UIElement>
  • point
    • Type:Point
HitTest(Rect)
  • rect
    • Type:Rect
IsAncestorOf(UIElement)
  • element
    • Type:UIElement
OnCreateAutomationPeer()
  • Type:AutomationPeer
GetOrCreateAutomationPeer()
GetAutomationPeer()
InvalidateAutomationPeer()
GetChildrenCount()
GetChild(Int32)
  • Type:UIElement
  • childIndex
BringIntoView()
BringIntoView(Rect)
  • targetRectangle
    • Type:Rect
GetIsUnloadingNode()
PegManagedPeerNoRef()
UnpegManagedPeerNoRef()
GetManagedReference(UInt32)
  • nPropertyID
    • Type:UInt32
RefreshExpression(DependencyProperty)
  • dp
EnsureValueTable()
SetValueInternal(DependencyProperty,Object)
  • dp
  • value
SetValueInternal(DependencyProperty,Object,Boolean)
  • dp
  • value
  • allowReadOnlySet
SetValueInternal(DependencyProperty,Object,Boolean,Boolean)
  • dp
  • value
  • allowReadOnlySet
  • isBindingInStyleSetter
ClearValueInternal(DependencyProperty)
  • dp
ReadLocalValueInternal(DependencyProperty)
  • dp
IsPropertyDefault(DependencyProperty)
  • dp
GetMentor()
PrepareCorePropertyExpression(DependencyProperty,Object)
  • property
  • value
InvalidateStyleBinding(DependencyProperty,Boolean&)
  • dp
  • hasLocalOrAnimatedValue
    • Type:Boolean&
SetValue(DependencyProperty,Matrix)
  • property
  • m
    • Type:Matrix
SetValue(DependencyProperty,Matrix3D)
  • property
  • m
    • Type:Matrix3D
SetValue(DependencyProperty,Point)
  • property
  • p
    • Type:Point
SetValue(DependencyProperty,DependencyObject)
  • property
  • doh
SetValue(DependencyProperty,Int32)
  • property
  • i
SetValue(DependencyProperty,Boolean)
  • property
  • b
SetValue(DependencyProperty,Enum)
  • property
  • e
    • Type:Enum
SetValue(DependencyProperty,Color)
  • property
  • c
    • Type:Color
SetValue(DependencyProperty,Double)
  • property
  • d
SetValue(DependencyProperty,GridLength)
  • property
  • g
    • Type:GridLength
InvalidateProperty(DependencyProperty)
  • property
GetOldValue(DependencyProperty,EffectiveValueEntry&)
  • property
  • oldEntry
    • Type:EffectiveValueEntry&
GetNewValue(DependencyProperty,EffectiveValueEntry&)
  • property
  • newEntry
SetEffectiveValue(DependencyProperty,EffectiveValueEntry&,Object)
  • property
  • newEntry
  • newValue
UpdateParentInheritanceContextPropagation()
SetAnimatedValue(DependencyProperty,Object)
  • property
  • animatedValue
ClearAnimatedValue(DependencyProperty,Boolean,Object)
  • property
  • hasHoldEndValue
  • holdEndValue
OnInheritanceContextChanged(Object,EventArgs)
  • sender
  • e
    • Type:EventArgs
AddEventListener(DependencyProperty,Delegate)
  • property
  • handler
    • Type:Delegate
AddEventListener(DependencyProperty,Delegate,Boolean)
  • property
  • handler
    • Type:Delegate
  • handledEventsToo
RemoveEventListener(DependencyProperty,Delegate)
  • property
  • handler
    • Type:Delegate
UpdateTreeParent(IManagedPeer,IManagedPeer,Boolean,Boolean)
  • oldParent
    • Type:IManagedPeer
  • newParent
    • Type:IManagedPeer
  • bIsNewParentAlive
  • keepReferenceToParent
UpdateTreeParentHelper(IManagedPeer,IManagedPeer,Boolean)
  • oldParent
    • Type:IManagedPeer
  • newParent
    • Type:IManagedPeer
IsPropertyLocal(CoreDependencyProperty)
  • dp
    • Type:CoreDependencyProperty
OnParentEnter(IntPtr,UInt32,UInt32,UInt32,UInt32)
  • nativeNamescopeOwner
    • Type:IntPtr
  • bLive
    • Type:UInt32
  • bSkipNameRegistration
    • Type:UInt32
  • bCoercedIsEnabled
    • Type:UInt32
  • bUseLayoutRounding
    • Type:UInt32
IsEnabled
Gets or sets a value that turns this map tool on or off.
FontSize
FontFamily
  • Type:FontFamily
FontWeight
  • Type:FontWeight
FontStyle
  • Type:FontStyle
FontStretch
  • Type:FontStretch
CharacterSpacing
Foreground
  • Type:Brush
IsTabStop
TabIndex
TabNavigation
  • Type:KeyboardNavigationMode
Template
  • Type:ControlTemplate
Padding
  • Type:Thickness
HorizontalContentAlignment
  • Type:HorizontalAlignment
VerticalContentAlignment
  • Type:VerticalAlignment
Background
  • Type:Brush
BorderThickness
  • Type:Thickness
BorderBrush
  • Type:Brush
Triggers
  • Type:TriggerCollection
Resources
  • Type:ResourceDictionary
ActualWidth
ActualHeight
Width
Height
MinWidth
MaxWidth
MinHeight
MaxHeight
HorizontalAlignment
VerticalAlignment
Margin
  • Type:Thickness
Style
  • Type:Style
Parent
FlowDirection
  • Type:FlowDirection
Tag
Cursor
  • Type:Cursor
Language
  • Type:XmlLanguage
DataContext
AllowDrop
Opacity
Clip
  • Type:Geometry
Effect
  • Type:Effect
Projection
  • Type:Projection
OpacityMask
  • Type:Brush
RenderTransformOrigin
  • Type:Point
IsHitTestVisible
Visibility
  • Type:Visibility
RenderSize
  • Type:Size
UseLayoutRounding
CacheMode
  • Type:CacheMode
DesiredSize
  • Type:Size
RenderTransform
  • Type:Transform
Dispatcher
  • Type:Dispatcher
Map
Gets or sets current map that the mapTool will be drawn on
ImplementationRoot
DefaultStyleKey
TagInternal
TemplatedParent
IsDataContextBound
IsDataContextChangingInternal
ChildrenInternal
  • Type:UIElementCollection
NativeObject
  • Type:IntPtr
NativeObjectSafeHandle
  • Type:NativeObjectSafeHandle
NeedsInheritanceContextChanges
IsInLiveTree
IsEnabledChanged N/A
Event Arguments:
Loaded N/A
Event Arguments:
Unloaded N/A
Event Arguments:
SizeChanged N/A
Event Arguments:
LayoutUpdated N/A
Event Arguments:
BindingValidationError N/A
Event Arguments:ValidationErrorEventArgs
DataContextChanged N/A
Event Arguments:
MouseMove N/A
Event Arguments:
MouseEnter N/A
Event Arguments:
MouseLeave N/A
Event Arguments:
MouseLeftButtonDown N/A
Event Arguments:
MouseLeftButtonUp N/A
Event Arguments:
MouseRightButtonDown N/A
Event Arguments:
MouseRightButtonUp N/A
Event Arguments:
MouseWheel N/A
Event Arguments:
KeyUp N/A
Event Arguments:
KeyDown N/A
Event Arguments:
MediaCommand N/A
Event Arguments:
GotFocus N/A
Event Arguments:
LostFocus N/A
Event Arguments:
LostMouseCapture N/A
Event Arguments:
TextInput N/A
Event Arguments:
TextInputStart N/A
Event Arguments:
TextInputUpdate N/A
Event Arguments:
DragEnter N/A
Event Arguments:
DragLeave N/A
Event Arguments:
DragOver N/A
Event Arguments:
Drop N/A
Event Arguments:
ManipulationStarted N/A
Event Arguments:ManipulationStartedEventArgs
ManipulationDelta N/A
Event Arguments:ManipulationDeltaEventArgs
ManipulationCompleted N/A
Event Arguments:ManipulationCompletedEventArgs
Tap N/A
Event Arguments:GestureEventArgs
DoubleTap N/A
Hold N/A
thinkgeo.mapsuite.silverlightedition.maptool.1442911143.txt.gz · Last modified: 2015/09/22 08:39 by admin
