thinkgeo.mapsuite.silverlightcore.pointstyles
ThinkGeo.MapSuite.SilverlightCore.PointStyles
    • ThinkGeo.MapSuite.SilverlightCore.PointStyles
CreateSimplePointStyle(PointSymbolType,GeoColor,Single)
Static API to create a point style.
  • Description:The created point style.
  • pointStyle
    • Description:This parameter determines the PointStyle symbol type.
  • fillColor
    • Type:GeoColor
    • Description:This parameter determines the PointStyle fill color.
  • size
    • Type:Single
    • Description:This parameter determines the PointStyle size.
CreateSimplePointStyle(PointSymbolType,GeoColor,GeoColor,Single,Single)
  • pointStyle
  • fillColor
    • Type:GeoColor
  • outlineColor
    • Type:GeoColor
    • Description:This parameter determines the PointStyle outline color.
  • outlineWidth
    • Type:Single
    • Description:This parameter determines the PointStyle outline width.
  • size
    • Type:Single
CreateSimplePointStyle(PointSymbolType,GeoColor,GeoColor,Single)
  • pointStyle
  • fillColor
    • Type:GeoColor
  • outlineColor
    • Type:GeoColor
  • size
    • Type:Single
CreateSimpleCircleStyle(GeoColor,Single)
Static API to create a circle point style.
  • fillColor
    • Type:GeoColor
  • size
    • Type:Single
CreateSimpleCircleStyle(GeoColor,Single,GeoColor,Single)
  • fillColor
    • Type:GeoColor
  • size
    • Type:Single
  • outlineColor
    • Type:GeoColor
  • outlineWidth
    • Type:Single
CreateSimpleCircleStyle(GeoColor,Single,GeoColor)
  • fillColor
    • Type:GeoColor
  • size
    • Type:Single
  • outlineColor
    • Type:GeoColor
CreateSimpleSquareStyle(GeoColor,Single)
Static API to create a square point style.
  • fillColor
    • Type:GeoColor
  • size
    • Type:Single
CreateSimpleSquareStyle(GeoColor,Single,GeoColor)
  • fillColor
    • Type:GeoColor
  • size
    • Type:Single
  • outlineColor
    • Type:GeoColor
CreateSimpleSquareStyle(GeoColor,Single,GeoColor,Single)
  • fillColor
    • Type:GeoColor
  • size
    • Type:Single
  • outlineColor
    • Type:GeoColor
  • outlineWidth
    • Type:Single
CreateSimpleStarStyle(GeoColor,Single)
Static API to create a star point style.
  • fillColor
    • Type:GeoColor
  • size
    • Type:Single
CreateSimpleStarStyle(GeoColor,Single,GeoColor)
  • fillColor
    • Type:GeoColor
  • size
    • Type:Single
  • outlineColor
    • Type:GeoColor
CreateSimpleTriangleStyle(GeoColor,Single)
Static API to create a triangle point style.
  • fillColor
    • Type:GeoColor
  • size
    • Type:Single
CreateSimpleTriangleStyle(GeoColor,Single,GeoColor)
  • fillColor
    • Type:GeoColor
  • size
    • Type:Single
  • outlineColor
    • Type:GeoColor
CreateSimpleTriangleStyle(GeoColor,Single,GeoColor,Single)
  • fillColor
    • Type:GeoColor
  • size
    • Type:Single
  • outlineColor
    • Type:GeoColor
  • outlineWidth
    • Type:Single
CreateCompoundCircleStyle(GeoColor,Single,GeoColor,Single,GeoColor,Single)
Static API to create a compound circle point style.
  • fillColor1
    • Type:GeoColor
    • Description:This parameter determines the outer circle's PointStyle fill color.
  • size1
    • Type:Single
    • Description:This parameter determines the outer circle's PointStyle size.
  • outlineColor1
    • Type:GeoColor
    • Description:This parameter determines the outer circle's PointStyle outline color.
  • outlineWidth1
    • Type:Single
    • Description:This parameter determines the outer circle's PointStyle outline width.
  • fillColor2
    • Type:GeoColor
    • Description:This parameter determines the inner circle's PointStyle fill color.
  • size2
    • Type:Single
    • Description:This parameter determines the inner circle's PointStyle size.
CreateCompoundCircleStyle(GeoColor,Single,GeoColor,Single,GeoColor,Single,GeoColor,Single)
  • fillColor1
    • Type:GeoColor
  • size1
    • Type:Single
  • outlineColor1
    • Type:GeoColor
  • outlineWidth1
    • Type:Single
  • fillColor2
    • Type:GeoColor
  • size2
    • Type:Single
  • outlineColor2
    • Type:GeoColor
    • Description:This parameter determines the inner circle's PointStyle outline color.
  • outlineWidth2
    • Type:Single
    • Description:This parameter determines the inner circle's PointStyle outline width.
CreateCompoundPointStyle(PointSymbolType,GeoColor,GeoColor,Single,Single,PointSymbolType,GeoColor,GeoColor,Single,Single)
  • pointStyle1
    • Description:This parameter determines the outer circle's pointstyle symbol type.
  • fillColor1
    • Type:GeoColor
  • outlineColor1
    • Type:GeoColor
  • outlineWidth1
    • Type:Single
  • size1
    • Type:Single
  • pointStyle2
    • Description:This parameter determines the inner circle's pointstyle symbol type.
  • fillColor2
    • Type:GeoColor
  • outlineColor2
    • Type:GeoColor
  • outlineWidth2
    • Type:Single
  • size2
    • Type:Single
    • Description:This parameter determines the inner circle PointStyle size.
thinkgeo.mapsuite.silverlightcore.pointstyles.1442805786.txt.gz · Last modified: 2015/09/21 03:23 by admin
