<!– Class –>
*System.Object ThinkGeo.MapSuite.Core.RasterSource *ThinkGeo.MapSuite.Core.FdoRasterSource ThinkGeo.MapSuite.Core.GdalRasterSource
FdoRasterSource | |||
FdoRasterSource | String, String | ||
FdoRasterSource | String, String, String | ||
FdoRasterSource | String, String, String, String | ||
FdoRasterSource | String, String, String, String, String |
CloneDeep | RasterSource | ||
Close | RasterSource | ||
![]() GenerateWorldFileText | RectangleShape, Int32, Int32 | RasterSource | |
GetBoundingBox | RasterSource | ||
GetHorizontalResolution | RasterSource | ||
GetImage | RectangleShape, Int32, Int32 | RasterSource | |
GetImageHeight | RasterSource | ||
GetImageWidth | RasterSource | ||
GetProjectionText | RasterSource | ||
GetVerticalResolution | RasterSource | ||
GetWorldFileText | RasterSource | ||
Open | RasterSource | ||
CloneDeepCore | RasterSource | ||
CloseCore | RasterSource | ||
GetBoundingBoxCore | RasterSource(overriden) | ||
GetImageCore | RectangleShape, Int32, Int32 | RasterSource(overriden) | |
GetImageHeightCore | RasterSource(overriden) | ||
GetImageWidthCore | RasterSource(overriden) | ||
GetProjectionTextCore | RasterSource | ||
MemberwiseClone | Object | ||
OnClosedRasterSource | ClosedRasterSourceEventArgs | RasterSource | |
OnClosingRasterSource | ClosingRasterSourceEventArgs | RasterSource | |
OnOpenedRasterSource | OpenedRasterSourceEventArgs | RasterSource | |
OnOpeningRasterSource | OpeningRasterSourceEventArgs | RasterSource | |
OpenCore | RasterSource(overriden) |
BlueTranslation | Single | RasterSource | |
ConnectionString | String | ||
FeatureClassName | String | ||
FeatureSchemaName | String | ||
GreenTranslation | Single | RasterSource | |
HasProjectionText | Boolean | RasterSource | |
IsGrayscale | Boolean | RasterSource | |
IsNegative | Boolean | RasterSource | |
IsOpen | Boolean | RasterSource | |
*Projection | Projection | RasterSource | |
ProviderName | String | ||
RasterColumnName | String | ||
RedTranslation | Single | RasterSource | |
Transparency | Single | RasterSource |
HasProjectionTextCore | Boolean | RasterSource |
| providerName | String<!– System.String –> | |
| connectionString | String<!– System.String –> |
| connectionString | String<!– System.String –> | |
| featureSchemaName | String<!– System.String –> |
| featureSchemaName | String<!– System.String –> | |
| featureClassName | String<!– System.String –> |
| featureClassName | String<!– System.String –> | |
| rasterColumnName | String<!– System.String –> |
| RasterSource<!– ThinkGeo.MapSuite.Core.RasterSource –> |
<!– ThinkGeo.MapSuite.Core.RasterSource –> Go Back
<!– static –>
| worldExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | |
| imageWidth | Int32<!– System.Int32 –> | |
| imageHeight | Int32<!– System.Int32 –> |
| GeoImage<!– ThinkGeo.MapSuite.Core.GeoImage –> |
| canvasWidth | Int32<!– System.Int32 –> | |
| canvasHeight | Int32<!– System.Int32 –> |
<!– ThinkGeo.MapSuite.Core.RasterSource(overriden) –> Go Back
| e | ClosedRasterSourceEventArgs<!– ThinkGeo.MapSuite.Core.ClosedRasterSourceEventArgs –> |
| e | ClosingRasterSourceEventArgs<!– ThinkGeo.MapSuite.Core.ClosingRasterSourceEventArgs –> |
| e | OpenedRasterSourceEventArgs<!– ThinkGeo.MapSuite.Core.OpenedRasterSourceEventArgs –> |
| e | OpeningRasterSourceEventArgs<!– ThinkGeo.MapSuite.Core.OpeningRasterSourceEventArgs –> |
<!– ThinkGeo.MapSuite.Core.FdoRasterSource –> Go Back
| Projection<!– ThinkGeo.MapSuite.Core.Projection –> |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
NOTOC FdoExtension ThinkGeo.MapSuite.Core UpdateDocumentation
