thinkgeo.mapsuite.silverlightcore.linestyle
ThinkGeo.MapSuite.SilverlightCore.LineStyle
This class is the style used to draw lines.
    • ThinkGeo.MapSuite.SilverlightCore.Style
      • ThinkGeo.MapSuite.SilverlightCore.LineStyle
LineStyle()
LineStyle(GeoPen)
Use this when you do not need any additional pens to draw the feature.
  • outerPen
    • Type:GeoPen
    • Description:This parameter is the outer pen used to draw the feature.
LineStyle(GeoPen,GeoPen)
This is a common constructor for drawing roads.
  • outerPen
    • Type:GeoPen
  • innerPen
    • Type:GeoPen
    • Description:This parameter is the inner pen used to draw the feature.
LineStyle(GeoPen,GeoPen,GeoPen)
This is common for drawing low level highways with center lines.
  • outerPen
    • Type:GeoPen
  • innerPen
    • Type:GeoPen
  • centerPen
    • Type:GeoPen
    • Description:This parameter is the center pen used to draw the feature.
  • features
    • Type:IEnumerable<Feature>
  • shapes
    • Type:IEnumerable<BaseShape>
GetRequiredColumnNames()
  • Type:Collection<String>
  • Description:None
  • features
  • canvas
    • Type:GeoCanvas
  • labelsInThisLayer
  • labelsInAllLayers
GetRequiredColumnNamesCore()
XOffsetInPixel
This property gets and sets the X pixel offset for drawing each feature.
This property allows you to specify an X offset. When combined with a Y offset, it is useful to allow you to achieve effects such as drop shadows, etc. There also may be times when you need to modify the location of feature data so as to better align it with raster satellite data.
  • Type:Single
YOffsetInPixel
This property gets and sets the Y pixel offset for drawing each feature.
This property allows you to specify an Y offset. When combined with an X offset, it is useful to allow you to achieve effects such as drop shadows, etc. There also may be times when you need to modify the location of feature data so as to better align it with raster satellite data.
  • Type:Single
CustomLineStyles
This property returns a collection of line styles, allowing you to stack multiple line styles on top of each other.
Using this collection, you can stack multiple styles on top of each other. When we draw the feature, we will draw them in order that they exist in the collection. You can use these stacks to create drop shadow effects, multiple colored outlines, etc.
OuterPen
This property gets and sets the outer pen for the line.
You can set an inner, outer and center pen to give you a nice effect. The outer pen draws first, and should typically be black and larger then the inner pen. The inner pen draws next, and should be set as the color of the road you want. It should be thinner than the outer pen. The center pen draws last, and is used to represent a centerline in the road. We suggest that you only use the center pen for highways at low zoom level, as the dashed pen has some performance penalties.
InnerPen
This property gets and sets the inner pen for the line.
CenterPen
This property gets and sets the center pen for the line.
IsActive
RequiredColumnNames
bho=
thinkgeo.mapsuite.silverlightcore.linestyle.1442805736.txt.gz · Last modified: 2015/09/21 03:22 by admin
