thinkgeo.mapsuite.routing.routinglayer
ThinkGeo.MapSuite.Routing.RoutingLayer
This layer can show start coordinates, end coordinates, a collection of in-between stops and the resulting paths with specified styles.
      • ThinkGeo.MapSuite.Routing.RoutingLayer
RoutingLayer()
  • This is the default constructor. If you use this constructor, then you should set the Routes property manually.
RoutingLayer(PointShape,PointShape,IEnumerable<PointShape>)
  • This constructor gets the points ready to use.
  • startPoint
    • Description:This parameter represents the startPoint that you want to use in this class.
  • endPoint
    • Description:This parameter represents the endPoint that you want to use in this class.
  • stopPoints
    • Type:IEnumerable<PointShape>
    • Description:This parameter represents the stopPoints that you want to use in this class.
RoutingLayer(IEnumerable<LineShape>)
  • For the most updated Info for this topic, please check it here:
  • routes
    • Type:IEnumerable<LineShape>
RoutingLayer(PointShape,PointShape,IEnumerable<PointShape>,IEnumerable<LineShape>)
  • stopPoints
  • routes
RequestDrawing()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#RequestDrawing.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#RequestDrawing.28RectangleShape.29
RequestDrawing(TimeSpan)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#RequestDrawing.28TimeSpan.29
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#RequestDrawing.28RectangleShape.2C_TimeSpan.29
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
GetThreadSafetyLevel()
CloneDeep()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#CloneDeep.28.29
  • Type:Layer
Open()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#Open.28.29
Close()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#Close.28.29
GetBoundingBox()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#GetBoundingBox.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#GetType.28.29
  • This method will draw the routing result based on the specified styles.
  • This abstract method is called from the concrete public method Draw. This method draws the representation of the layer based on the extent you provided. When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
  • canvas
    • Type:GeoCanvas
    • Description:This parameter is the canvas object or a GeoImage to draw on.
  • labelsInAllLayers
    • Description:This parameter represents the labels used for collision detection and duplication checking.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#OnRequestedDrawing.28RequestedDrawingLayerEventArgs.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#OnRequestingDrawing.28RequestingDrawingLayerEventArgs.29
GetThreadSafetyLevelCore()
CloneDeepCore()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#CloneDeepCore.28.29
  • Type:Layer
OpenCore()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#OpenCore.28.29
CloseCore()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#CloseCore.28.29
GetBoundingBoxCore()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#GetBoundingBoxCore.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#DrawException.28GeoCanvas.2C_Exception.29
  • e
    • Type:Exception
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#DrawExceptionCore.28GeoCanvas.2C_Exception.29
  • e
    • Type:Exception
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#OnDrawingException.28DrawingExceptionLayerEventArgs.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#OnDrawnException.28DrawnExceptionLayerEventArgs.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#DrawAttributionCore.28GeoCanvas.2C_String.29
  • attribution
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#OnDrawingAttribution.28DrawingAttributionLayerEventArgs.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#OnDrawnAttribution.28DrawnAttributionLayerEventArgs.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#OnDrawingProgressChanged.28DrawingProgressChangedEventArgs.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#MemberwiseClone.28.29
XOffsetInPixelOfStopOrder
Gets or sets the x offset (in pixels) of the stop order.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#XOffsetInPixelOfStopOrder
  • Type:Single
YOffsetInPixelOfStopOrder
Gets or sets the y offset (in pixels) of the stop order.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#YOffsetInPixelOfStopOrder
  • Type:Single
Routes
Gets the result path information for routing.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#Routes
StartPoint
Gets and sets the start coordinates for routing.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#StartPoint
EndPoint
Gets and sets the end coordinates for routing.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#EndPoint
StopPoints
Gets a collection that holds the stop coordinates between StartPoint and EndPoint for routing.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#StopPoints
StartPointStyle
Gets and sets the style of StartPoint.
If this property is not set, the default style is a small green marker representing the route start point.
EndPointStyle
Gets and sets the style of EndPoint.
If this property is not set, the default style is a small red marker representing the route end point.
StopPointStyle
Gets and sets the style of StopPoints.
If this property is not set, the default style is a small yellow marker representing a stop.
StopTextStyle
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#StopTextStyle
RouteStyle
Gets and sets the style of Routes.
If this property is not set, the default style is a purple pen with semitransparent color.
ShowStopOrder
Gets and sets the value that represents whether to show the ordinal number of each of the StopPoints when drawing layer. The default value is true.
If this property is set to false, the text representing the sequence number of each stop will not be shown. This is ensured in the Draw method.
RequestDrawingInterval
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#RequestDrawingInterval
  • Type:TimeSpan
IsOpen
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#IsOpen
HasBoundingBox
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#HasBoundingBox
DrawingTime
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#DrawingTime
  • Type:TimeSpan
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#Name
Attribution
IsVisible
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#IsVisible
Transparency
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#Transparency
  • Type:Single
BlueTranslation
  • Type:Single
RedTranslation
  • Type:Single
GreenTranslation
  • Type:Single
KeyColors
IsNegative
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#IsNegative
IsGrayscale
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#IsGrayscale
DrawingExceptionMode
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#DrawingExceptionMode
IsOpenCore
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#IsOpenCore
RequestedDrawing N/A
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#OnRequestedDrawing.28RequestedDrawingLayerEventArgs.29
RequestingDrawing N/A
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#OnRequestingDrawing.28RequestingDrawingLayerEventArgs.29
DrawingProgressChanged N/A
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#OnDrawnException.28DrawnExceptionLayerEventArgs.29
DrawingAttribution N/A
thinkgeo.mapsuite.routing.routinglayer.1442910772.txt.gz · Last modified: 2015/09/22 08:32 by admin
